Propane addition
Old May 28, 2004 | 06:15 PM
redneckdieselmechanic's Avatar
Propane addition
I'm considering a homemade propane injection setup on my 84 F150 351W carbed motor. I saw this article in the diesel section http://www.members.shaw.ca/k2pilot/...%20article.html and am wonderin if this same setup would work on a gasser. I have a open element so I guess Id have to rig up the nozzle through the breather lid. Any suggestions?
Old May 28, 2004 | 07:04 PM
jmalecek's Avatar
jmalecek
What about a plate system from a nitrous kit for injection? As far as propane mixing, I don't have a clue. I think it would be a good idea to save on fuel consumption.
Old May 30, 2004 | 04:37 AM
About that nitrous injection plate, I dont reckon they even make one of those for the early 80's carbed small block Fords. Before I even attempt to gather the parts for this setup I'm still wonderin' if the propane would even do much good on a mostly stock motor. Only mods it has is a small cam and headers. Anyhow, I was changing the intake gaskets, valve cover gaskets, and rebuilding the carb today and I got it all back together and runnin' but I'm guessing the EGR valve is stuck due to enormous amount of carbon that I had to dig out of the EGR plate under the carb. The plate was totally blocked off both ways. So I cleaned it out real good, flushed the radiator and block, and rebuilt the carb. Now it's really runnin' like a dog and real hot too. Any suggestions as to how much a stuck EGR valve is affecting this motor?
Old May 30, 2004 | 06:25 AM
Oh, forgot to add this...There's some kind of metal hose that draws fresh air inside the breather and goes into the left side of the intake manifold then loops around a couple times, then goes into the choke housing. It passes through one of the EGR ports in the manifold. When I did the job on the truck I had to take that piece off and was wonderin' whats the name of this part so I can get a gasket to fix the bad a$$ exhaust leak.
Ford-Trucks Editors
Alternative Fuels, Hybrids & Mileage
Jan 12, 2012 07:41 PM
TexasRenegade
16
Feb 24, 2011 06:38 PM
KyleG
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 26, 2008 06:38 AM
mokicoolcruz
Apr 13, 2008 10:14 AM
