what is this part??
Old May 28, 2004 | 10:35 AM
biggreen78's Avatar
biggreen78
what is this part??
i was cleaning the intake maniford of wasps nests when i decided to take everything off and clean it all. there were two bolts holding this peice on right next to the carb on the left of my 351m. there was a coil piece on the inside which stuck into the manifold and two pieces that were connected to hoses. i don't remember what the hoses go to cuz im at wok right now. i accidentally bent one of the pieces to where it cracked. at pep boys they didn't have a replacement nor tell me what the piece was or where to get it (go figure) i bought some jb weld and put it back on. any help as always is appreciated
where can i buy this piece and how much should i expect to spend. i know someones going to tell me to go to the boneyard, but i don't have time for that with work and school and being a daddy. Thanx again- Matt
Old May 28, 2004 | 03:41 PM
werkdatool's Avatar
werkdatool
biggreen78,
That is the choke heater. if you have electric choke keep it, if you have a manual choke, there is a block off plate available for that.
Hope this will help.
Werk
Old May 28, 2004 | 03:49 PM
biggreen78's Avatar
biggreen78
if i were to buy a new intake maniford, then will i retain this piece or would the new unit come with it??
i was considering the weiand 8180 or the edelbrock performer. both are dual plane i am also going to be getting the edlebrock performer 600cfm carb, and im pretty sure it will work with both of these sound about right??
Old May 28, 2004 | 04:47 PM
bubbaf250's Avatar
bubbaf250
The flat piece with coiled tubing is the heat exchanger for the choke's hot air system. You can get it from a Ford dealer for about $15. The part number is D5AZ-9C869-A.
It will work with the aftermarket intake manifolds, but it is not supplied with those manifolds.
PAwhiteboy
Jan 8, 2012 11:59 PM
tbm3fan
18
Jan 24, 2011 12:49 PM
wib714
1983 - 2012 Ranger & B-Series
Aug 30, 2008 07:51 AM
GreatNorthWoods
Sep 3, 2006 03:50 PM
maa139
Jan 29, 2005 08:59 PM
