stroke question
Old May 27, 2004 | 09:38 PM
2ndmouse's Avatar
2ndmouse
stroke question
I measured the stroke in my 390 like i have read here to do. a strieght piece of wire, piston at the bottom of the stroke, wire in the spark plug hole. I carefully put the wire in, as streight as i could touched the center of the piston and marked the wire with a sharpie. i put the mark at the bottom of the spark plug threads.
its 5 inches exactly. (on #1) to the top of the threads is 5 1/4 or close to it.
I measured it 3 times, bottom of the threads to the piston surface is 5 inches on the nose.
I read it should be, for a 390, 3 3/4..
I read 5" what did I measure wrong or do I have a different engine?
does the heads make a diff? the chick said they put 428 heads on it.
Old May 27, 2004 | 09:57 PM
gtex's Avatar
gtex
you want to measure it at the bottom and top of the stroke. then the difference is your stroke.
Old May 28, 2004 | 01:10 AM
2ndmouse's Avatar
2ndmouse
Oh I see, thanks... the diference measured 3 1/2 so I guess I have a 360.
thanks for correcting me!
one more thing the owner told me that wasnt true... oh well.
it runs its paid for. i'm happy with it.
Old May 28, 2004 | 10:21 AM
BB's Avatar
BB
Try it again, it takes a little practice.
This time put the engine at TDC and remove spark plugs #1 and #4. Stick it in hole #1 and mark the wire, then put it in hole #4 and mark the wire again. Don't turn the engine over, leave it at TDC.
Hopefully you get a 390 now.
Old May 28, 2004 | 02:14 PM
2ndmouse's Avatar
2ndmouse
a dowl rod works better, so does the 1 and 4 plug out and not moving the engine.
it's 3 3/4 every time I try it. the wire I was using last night was reading a bit over 3.5, but the pre marked dowl i dont have to mark, just look in the plug hole and make sure 1 and 4 are measured off the same spot.
cool.. I have a 390 again.
Thanks BB!
Old May 28, 2004 | 03:57 PM
BB's Avatar
BB
Excellent!
raven3
Jan 15, 2015 04:22 PM
Duckmang
Jul 4, 2013 02:45 PM
bamaf150
Jun 4, 2011 01:27 AM
tatonka04
Sep 12, 2008 07:54 AM
Dirt Head
Jun 6, 2004 03:42 PM
