Gas Mileage Expectations
Old May 28, 2004 | 02:29 PM
RX 1 Liter's Avatar
RX 1 Liter
Nighthawk,
To answer your question, the EPA rated the 4.6 and the 3v 5.4 as both 14 city and 18 highway. While the 4.6 will pull your boat you will be very displeased with a 4.6 if you drive a 5.4. I pulled very similar loads and my 97 f150 had the 4.6. Now that I have the 5.4, there is a night and day difference between the two. You will definitely regret getting the 4.6.
Old May 28, 2004 | 03:22 PM
geno87_69's Avatar
geno87_69
I have a 5.4 with 3.73.
Highway I get 16.5 mpg.
Towing my 6000 lbs camper at 65 mph I get 8.5mpg.
sprintcarcrazy's Avatar
sprintcarcrazy
Lariat 5.4 crew, 3.73ls, 13.5 mpg city, 16.5 mpg hwy, 9.7 towing 5000lb camper.
Old May 28, 2004 | 03:26 PM
froste's Avatar
froste
dhollist---Here in MO the speed limit is 60, i usually drive around 65 and still maintain the 16-17 mpg but like i said this is with about 70% highway miles
Old May 29, 2004 | 09:06 AM
Den01's Avatar
Den01
NightHawk
There is nothing worse then driving a under powered truck. I had the 97 F150 with the 4.6L. It drove fine empty, loaded it sucked. My 2000 had the 5.4L and it was great. I pulling 5000# loads through Mountains did pretty good. I now have the FX4 5.4L with 3.55 LSD. With 50/50 driving I am getting 14.8-15.7 with 86 octane. Hwy miles at 80 mph I have gotten 17.9 mpg.
IMO you are better off with extra power not being used then getting into a situation where you need the power and dont have it
Old May 29, 2004 | 10:27 AM
ANAP's Avatar
ANAP
I have 2004 FX4 5.4L 3.73 gears......I am only getting about 13.5 miles a gallon.....60% city 40% hwy....
You guys think the new computer flash will help me out? I should be getting atleast 15 MPG I would think if not 16MPG AVG.
