Help, 4x4 not working
Old May 26, 2004 | 01:43 PM
JLMoreno911's Avatar
JLMoreno911
I have a 91 Explorer XLT, the 4x4 worked fine, then one day I pressed the the 4H button and no response. Nothing, not either light indicater comes on, I don't hear it engage either. I checked the fuses and they are good. I havent taken the switch apart to see if it is getting voltage or not, but if you have any idea on what the problem is and how to correct it, I really appreciated your help. Thanks
Old May 26, 2004 | 05:38 PM
Bashman's Avatar
Bashman
Most likely your shift motor needs cleaning. This is very common on 1st Gen (91-94) Ex's. Here's a link with pics that takes you through everything about it.
https://www.ford-trucks.com/lc/lc.ph...gletn/exp.html
Old May 27, 2004 | 03:05 PM
JLMoreno911
Thanks Bashman, but it really doesnt cover my problem.
Still haven't had a chance to get a good look at it.
Old May 27, 2004 | 05:05 PM
Cptn727's Avatar
Cptn727
Eh... I agree with bashman. What you're describing has happened to a lot of vehicles in that generation, and frequently for that reason. What makes you think it's not the T-Case shift motor?
Old May 27, 2004 | 05:19 PM
mustangsvt's Avatar
mustangsvt
take it to the dealer....also one piece of advice for you...only use 4WD when your in heavy snow or sand. Do NOT use on dry or wet roadways, no matter if its flooded or not. this will burn up the 4WD very quickly
gottahaveaford
1978 - 1996 Big Bronco
Feb 9, 2015 10:25 AM
mikie1977
Feb 23, 2014 10:12 AM
staceylamm
1983 - 2012 Ranger & B-Series
Aug 5, 2011 09:18 AM
f-4x4
Oct 20, 2004 01:30 AM
18fan
Sep 6, 2003 04:21 PM
