another tachometer hookup question
Old May 26, 2004 | 12:37 PM
ksvtwin's Avatar
ksvtwin
I'm still trying to hook that tach up in my sons '95 ranger 4 cyl. There isn't a tachometer hook up on the schematic for '95 rangers but there is supposed to be a tan/yellow wire on the '92 through '94 rangers. i've been told by others to find a tan/yellow wire but i just can't seem to locate it. i've looked under the dash. does anyone have any suggestions on this? I appreciate it, Kent
Old May 26, 2004 | 05:56 PM
maticuno's Avatar
maticuno
Easiest place to find it is coming out of the ECU. On the firewall. It's a pain to dig through all the wires to isolate it, but it's how I accomplished it. Just spliced in and ran a new wire through the firewall and under the dash.
Old May 26, 2004 | 08:18 PM
Vin 95's Avatar
Vin 95
I think I read a post that said that wire is ran to the dash cluster,so that if you get a same year model dash with a tach,you just swap them and plug it in,and your good to go.
Old May 27, 2004 | 07:02 AM
ksvtwin's Avatar
ksvtwin
I found the wire in the cluster of wires, it was on pin number 48. I hooked it up and it works great! thanks for all the advice!! KS
thehawk75
Jul 8, 2012 08:17 PM
burg95f250
Feb 14, 2010 07:17 PM
ksvtwin
May 24, 2004 03:27 PM
faroffthetrack
May 20, 2004 04:13 PM
adidasab03
Jul 16, 2003 12:16 PM
