Rear Wiper does not work
Old May 26, 2004 | 10:00 AM
ratast440's Avatar
ratast440
I have a 2000 Expedition and the rear wiper does not work. I have checked the fuse and thats ok. The problem comes and goes, it has done this 3 or 4 times in the past year. And at this present time it is not working, it's been this way for the past 2 months. Any help would be greatly appreciated.
Old May 26, 2004 | 10:05 AM
ferroequine's Avatar
ferroequine
I've heard that the rear wiper motors in our Expeditions are prone to failure. The good news is that a new motor isn't that expensive. I'm hoping to keep the one in my own '00 going though...
Old May 26, 2004 | 10:12 AM
Donw35's Avatar
Donw35
My 01 Expy was replaced twice under warranty. my 98 Explorer once and my 96 Explorer once also, I would say that Ford has bad wiper motors. I hope my 04 EB doesn't have the same issues.
Old May 26, 2004 | 11:27 AM
dakota_viking's Avatar
dakota_viking
I've had the same problem from time to time. I have found that if I turn on the wiper and slam the back door or glass, sometimes just wiggle the handle, it will start to work again.
The rear wiper works on an interlock system so that it does not activate if the door or window is open. My guess is that sometimes the latches are sticking and keeping the circuit open. This goes along the same lines as the dome light staying on when all the doors are shut.
You may want to shoot a little WD-40 into the latches.
Just my .02
Tim
Old May 26, 2004 | 05:53 PM
seismojones's Avatar
seismojones
Post Same problem w/ 98 Expy
My Expedition has the same problem. Sometimes would work, sometimes wouldn't. It hasn't worked for about 6 months now. Tonight I decided to fix it so I opened everything up back there. It must be a bad motor. I can hear it clicking when it's supposed to be moving but alas - no movement.
I've been unsuccesfully trying to find a replacement motor on the web.
The motor says:
VALCO 4/3-00399 055.8
4BE
5490 17 62
Anways, got on this site to try and find a solution and ran across this thread.
Guess it's off to Ford buy this part.
Old May 27, 2004 | 09:16 AM
buzzard's Avatar
buzzard
Here's an older thread with a lot of info.
https://www.ford-trucks.com/forums/s...ht=rear+wiper+
Old May 27, 2004 | 01:12 PM
PaulC's Avatar
PaulC
My third wiper motor is now about two years old and is still working. I wonder if Ford has instituted some type of running change on the design?
You know, of course, that I've just jinxed myself.
Old May 28, 2004 | 01:07 PM
seismojones
Ford wanted $81 for the part.
Autozone - $39.99.
Guess where I'm buying it.
Old May 28, 2004 | 03:09 PM
mahause's Avatar
mahause
Mine quits working every once in a while. I push up on the wiper with the switch on and it takes off. I figure sooner or later I'll have to replace the motor.
Old May 28, 2004 | 06:25 PM
HomerWinzlow's Avatar
HomerWinzlow
A lot of the repeat failures occured due to improper installation. In fact many of the originals were improperly installed on the assembly line and that initiated the problem. Then techs stuck on a new one and didnt follow the included instructions, and sure enough repeat failure. This failure can result from improper replacement of the wiper arm as well. I guess Ive been lucky. My 00 still has the original and never a problem.
Old May 29, 2004 | 05:21 PM
latinhustle's Avatar
latinhustle
ive taken mine in 3 times to be replaced, getting ready to go in a 4th....
Old May 29, 2004 | 06:20 PM
mm7759's Avatar
mm7759
I had the same problem on my 2000. I was at the dealer one time, and mentioned it. He said it's a known problem (but I don't remember if there was a recall on it). He said Explorers also had the problem. What he told me was it has something to do with the contacts in the motor. Sometimes they don't make good contact. What he told me to try was when they didn't work to try to "bump" the wiper arm up and it should star working.....and if I continued to have problems, bring it in and they will replace them. I was still under warranty at the time, so I can't say for sure if there was a recall or if that would just be covered under warranty?? I had a friend that took his in and had it replaced. I don't think it was too costly. Too bad I didn't know he was taking his in for the same issue. He told me AFTER he had his fixed. Good Luck!
Old Jun 5, 2004 | 02:25 PM
wolvesfan's Avatar
wolvesfan
Angry
Mine quits working when, guess, it rains... It works fine with the washer, but quits in a heavy rain... And sometimes my front wipers go on when I lower the drivers window... Where's the Twilight Zone music when I need it????
jd0245
Mar 24, 2017 08:49 PM
Jesser02EX
Mar 4, 2014 06:31 PM
GTBksRule
Electrical Systems/Wiring
Feb 9, 2013 08:16 AM
makthenif
Sep 18, 2012 06:56 PM
