Sponsored by: Real Truck
Airbag code 4-7
Old May 25, 2004 | 10:08 AM
PreacherTech's Avatar
PreacherTech
Question Airbag code 4-7
2002 F250 SD. Airbag light blinks 4 then 7 and repeats this sequence several times, then stays on solid. Anyone know the meaning of this code? After repair, how do you reset the code reporter.
Thanks
Old May 25, 2004 | 12:46 PM
krelvinaz's Avatar
krelvinaz
The 4 codes are sensor errors. I have not seen a chart that shows 47 though. Most stop at 45. I would guess that it is an additional sensor that has been added so that 46 and 47 would be valid. If that is the case, it indicates that that sensor is bad.
As for resetting it... don't know. maybe just fixing the sensor fixes it.
Old Sep 2, 2006 | 03:25 AM
VULCAMOIA's Avatar
VULCAMOIA
Airbag Light Code 47
hi thread,i have a ford ranger 2001 with the same problem.Let me tell you that you DON'T need to take your truck to the dealer.it's not necesary.
Code 47 means that the pretensioner in the seatbelt in the passanger side is failing and in case of an accident,the airbag would not deploy.
What you need to do to get it fixed,pull the seat belt all the way out,and then let it go back by itself.after doing this if the light is still ON or flashing the code 47,you may check the airbag cables under the passanger side seat .
I did it and the problem is GONE and it was FREE!!!
good luck
P.S:you don't need to reset or disconnect any cable or fuses.This is the way it works.
Old Apr 2, 2019 | 01:42 AM
Emma1234's Avatar
Emma1234
Hello Vulcamoia
I specifically joined this forum just to say a big THANK-YOU to you as you have helped me fix my airbag light problem in my 2010 Ford Escape. My problem with the 4-7 flashing light started happening around a week ago and just before then, I'd had the car serviced. I thought that perhaps the new guy that serviced my car had accidentally touched something that had triggered the fault. After reading your post, and before calling the mechanic thank goodness, I thought I would try pulling the seatbelt all the way out and letting it go back in by itself like you suggested. I did this a few times but it didn't remedy the problem. I then read on in your post that it could be the cables under the seat. I remembered that I had had a water bottle under the passenger side seat that would knock around when I went round corners etc. I thought that maybe this had dislodged a wire under the seat. I was right! It was still connected but only just. As soon as I plugged it all the way back in, I turned on the Escape and no more warning light for the airbag!!! So once again, thank-you so much. I didn't need another expense at this moment and you saved me potentially big bucks.
Many, many thanks,
Em.
xx
Old Apr 10, 2019 | 04:13 PM
Charlie Doc's Avatar
Charlie Doc
My 2001 F250 just started showing airbag warning light. It blinked four then six times, 46 code. That indicated driver seat problem. Found online answer that said unplug yellow connector under seat, then reconnect it. Magic! That cured the problem! First answers I found said go to dealer ASAP! I try to avoid that when possible, glad I checked further for answer.
esten07
2004 - 2008 F150
Dec 12, 2015 07:42 AM
BLAVET4X4
2004 - 2008 F150
Aug 13, 2011 11:40 PM
Normmus
1983 - 2012 Ranger & B-Series
21
Jan 20, 2011 06:49 PM
SillySod
Oct 29, 2010 07:53 PM
QIKSTAND
Aug 16, 2007 11:00 AM
