1978 - 1996 Big Bronco
Third break light w/ top off...
Old May 25, 2004 | 05:40 AM
GotLift's Avatar
GotLift
Anyone ever get pulled over for not having a third break light with the top off? I want to take my top off this summer and I'm banking on the average cop not knowing the difference unless they own a Bronco. I suppose I'll have to get some lap belts for the rear too.
Old May 25, 2004 | 06:16 AM
3broncocrazy's Avatar
3broncocrazy
I've never had any problems............not to say you wont
Old May 25, 2004 | 09:28 AM
Crazyromi's Avatar
Crazyromi
Its not a problem if you have a 1991 or earlier Bronco. They changed the laws in 92 to require the third stop light, so technically it is illegal to do it on a 92-96 Bronco. It would take an incredibly **** cop to get you a ticket for that. I think it's worth the risk though. If you are real scared though, you could always do this:http://www.superford.org/registry/ve...=17255#content
Old May 25, 2004 | 09:18 PM
JoeBlow's Avatar
JoeBlow
Do you have a hitch? if so, why not get a brake light hitch cover? They plug into your trailer wiring harness.
Old May 26, 2004 | 07:06 PM
Jaken86's Avatar
Jaken86
dont think youll have problems
whats the year has to be 87 and above?
its a law for car companies to put the third light on in 1987. you should be good
if you do get pulled over tell the cop its an 86 they werent rewuired then
Old May 26, 2004 | 07:08 PM
Jaken86's Avatar
Jaken86
damnit
required i meant
Old May 26, 2004 | 07:09 PM
ubermich's Avatar
ubermich
Just wire a single LED (available from ratshack, shouldn't be more than $2) on the circuit with a reasonable resistor. "Sure it's there, it's the ultra-mini-compact version. They were only available on 3,000 Broncos in (your truck's year here)."
Edit: here's an LED calculator if you want to do this http://linear1.org/ckts/led.php Just plug in the information for the circuit and it will tell you what resistor you need.
Old May 27, 2004 | 10:51 PM
FBB93's Avatar
FBB93
Jaken 86- I think they started putting them in the 92's. thats also when they started with the rear shoulder belts.
Old May 28, 2004 | 01:56 PM
3broncocrazy
When the top is removed, I just use the shoulder belt as a lap belt......Seems to do just fine.
betrayz
Jun 28, 2015 08:52 AM
mmanos1
May 24, 2015 08:01 PM
thehat
1997 - 2003 F150
May 5, 2008 03:35 PM
paintguy1
Electrical Systems/Wiring
Sep 12, 2004 07:25 PM
dtparks
Mar 5, 2003 08:43 PM
