Sponsored by: Auxito
trans problem
Old May 25, 2004 | 01:42 AM
98 4.6 locked up's Avatar
98 4.6 locked up
trans problem
Took truck out for a short drive yesterday and the thing went nuts! Lost 3rd gear(engine just revs when it gets there), Lost turn signals and my ABS lights came on and truck braked very strange. It wanted to lock up. Im mostly concerned with the trans problem. Could this be an electrical issue? I seem to be having alot of those. Possibly trans sensor? It is a 98 F-150 EXT with a 4.6 and 4r70w.
Old May 25, 2004 | 07:21 PM
98 4.6 locked up
Any ideas anybody? Someone told me today it could be the alternator not throwing enough current. The battery did die the other day for no reason. It is a new battery.
Old May 25, 2004 | 10:25 PM
jonny02's Avatar
jonny02
tmore than likely the reason ur brakes seemed strange was cause ur brakes were working w/o the abs on. usually when that light comes on they revert to normal braking. im just learning about this though so dont take my word on it. if it is the alternator u can test it with a multimeter to see if its puttin out the right volts. it does almost sound like to alternator isnt workin right casue i forgot to hook mine up once and the speedo said i was doin 75mph and i was doin more like 35 and all the lights started flashin at me then it died.
Old May 27, 2004 | 07:46 PM
98 4.6 locked up
Checked voltage at battery today and it read 30.3 volts! Would this be a simple change of the alternator or is there an external voltage regulator somewhere? Do you think this could have fried some sensors? Mainly concerned with the speed sensor since I have no third gear all of a sudden. Could this effect any other things like abs and 4x4. Jordan
Old May 27, 2004 | 08:31 PM
LxMan1's Avatar
LxMan1
It could have fried the GEM and could have possibly burnt the PCM to some extent. Your bulbs probably blew out with 30v going to them.
fmfire672
2004 - 2008 F150
Mar 3, 2010 01:31 PM
bheneee
Modular V8 (4.6L, 5.4L)
Jul 21, 2009 09:31 PM
smoke n tires
Jan 24, 2008 08:16 PM
98 4.6 locked up
1997 - 2003 F150
Feb 5, 2004 11:39 PM
Charlie Santi
Oct 1, 2003 06:12 PM
