Power Stroke Conversion
Old Sep 8, 2001 | 04:12 PM
Hammerham's Avatar
Hammerham
I have a 78 F-250 4X4 With a blown 351M in it has anyone or is there anyone out there that has done a conversion and if so how difficult is it and what is involved?
Can the c-6 auto still be used with the default set up?
Can you stay with the original gas tank?
wiring, motor, mounts, cooling. those sort of things
Thanks
David
Old Sep 8, 2001 | 07:04 PM
The Diesel Dude's Avatar
The Diesel Dude
Old Sep 13, 2001 | 02:29 AM
Roaring's Avatar
Roaring
I had asked a similar question earlier and got the reply.. yes you can but bring your check book because it will be expensive as you will have to change the wiring harness and alot of other things... it is cheaper to buy a truck with a diesel motor in it... hope this helps you
good luck
Roaring
david00f150
Sep 18, 2006 12:34 AM
maddogmauldin
Oct 17, 2004 09:24 AM
dbarracuda
Oct 2, 2003 08:59 PM
dbarracuda
Sep 10, 2003 05:32 PM
