Adding AC to 79 F250 - Distributor Problem
Old May 23, 2004 | 06:45 PM
davemccorkle's Avatar
davemccorkle
I have a 79 F250 with a 400 engine. I recently got all parts needed to add AC. After I put on the brackets for the compressor I noticed that the vaccum advance on my distributor is in the way of the compressor. Could it be that I need to pull the distributor and turn it one tooth to the left? How much timing trouble will I get in to if I do this?
Please Help!1
Old May 23, 2004 | 07:25 PM
pdqford's Avatar
pdqford
Should be okay if you re-time the engine. But be sure the distributor shaft re-engages the oil pump shaft.
Old May 23, 2004 | 08:42 PM
KenB's Avatar
KenB
I've had 'em set up that close from factory. Should be fine as long as you don't have to adjust past the stop, then you'll have to move dist. gear yet another tooth.
Or- You could put in an electronic dist.
Old May 23, 2004 | 08:45 PM
davemccorkle
Thanks for all the help guys I will give it a try.
Old May 23, 2004 | 08:51 PM
thelonerangerxlt's Avatar
thelonerangerxlt
FYI, the vacuum advance can is supposed to point directly toward the radiator, if the distributor is set in it's stock configuration (with A/C).
tomwerm
Jan 28, 2015 09:19 AM
lrdvdr41
Jul 7, 2014 02:46 PM
Powerstroke1995
Electrical Systems/Wiring
24
Oct 10, 2007 10:20 PM
79beater
Sep 17, 2005 12:55 PM
