Rear End
Old May 22, 2004 | 09:30 PM
REBELREENACTOR's Avatar
REBELREENACTOR
Rear End
I Have A 55 Panel Truck And Have Put A Cordoba Front End On It For Power Steering And Brakes, The Question I Have Is What Chrysler Rear End Will Fit On The Truck So I Have Matching Rims.
Thanks
Old May 22, 2004 | 09:39 PM
ferguson777's Avatar
ferguson777
Mopar and Ford both used a 5 X 4.5 bolt pattern. It is believed the hub protrusion on the Mopar is a larger diameter than the Ford. Meaning, you can go with a Ford 8.8 or 9" rear end using the 5 X 4.5 bolt pattern (see suitable donors above in the rear axle stickied note at the top of the this forum) and the Mopar front hubs by using "Mopar" wheels. (Presumably Ford wheels would not fit over the Mopar hub.)
Later,
Old May 23, 2004 | 10:33 AM
truckfarmer's Avatar
truckfarmer
I have a 63 Galaxy 9" rearend in my 56. It is 1" narrower than the stock rearend. Also look for 61-64 Galaxy, 71-73 Mustang/Cougar, 68-71 Torino/Fairlane, Montego, Ranchero. They will all need to have new mounts welded in the correct position for the truck.
cts1954
Mar 11, 2013 03:01 PM
jas88
Feb 26, 2013 08:34 PM
cwb
Nov 17, 2004 08:22 AM
GreatNorthWoods
Aug 30, 2004 04:24 PM
GreatNorthWoods
24
Oct 27, 2002 10:25 PM
