Offroad & 4x4
Hot Hub
Old May 22, 2004 | 06:32 PM
Commo's Avatar
Commo
Hot Hub
Hey group.
The other day my son and I were out playing and after about 3 hours we headed back. Trail riding no crazy stuff. When we got back to civiliaztion, we stopped, put it into 2wd and unlocked the hubs. The hub on the drivers side was warm but not too warm. The hub on the passenger side was too hot to touch comfortably.
Whats the collective opinion? Bearings or something worse?
Thanks
96 F150 Supercab short wb 4X4 manual Warn hubs 4" BL 33X12.5 BFGs
Roland
Old May 22, 2004 | 10:16 PM
Idiomaticman's Avatar
Idiomaticman
the brake in that side might drag a little more than they otherside. i would recommend tearing down both hubs and spindle assemblies and regreasing everything, and cleaning it all out. if you have disc brakes they should self adjust to make everything perfect. make sure you torque everything to spec using the correct tool. IE a hammer and flathead screwdriver is not a hub socket.
Idio
Old May 22, 2004 | 10:23 PM
bremen242's Avatar
bremen242
I'd say you need a new wheel bearing or spindle bearing. I'd pull everything and clean it like idio said..
Old May 23, 2004 | 06:29 PM
proeliator's Avatar
proeliator
If it needs to be greased badly they can get warm. Although, if its dry enough to cause heat like that, you can be sure your bearings need replaced too.
Old May 24, 2004 | 10:28 AM
Commo's Avatar
Commo
Thanks guys.
I'm thinking worse case. The bearings were just repacked about 2 months/500 mi ago and the mech said the spindles would need replacing in the near future.
Thats gonna leave a bruise. :-(
Roland
Old May 25, 2004 | 01:24 AM
AJ Goss's Avatar
AJ Goss
It's more common for the calipers to seize up and not release the rotor, causing heat buildup. I just replaced the entire front brake system on my truck because that kept happening to me. If you end up going that route, I'd replace the bearings as well. They're cheap.
Why do the spindles need to be replaced?
deputydog03
Dec 10, 2015 07:40 PM
t_dub
Sep 5, 2015 10:27 PM
timday627
Jun 18, 2014 10:10 AM
crobotti
Apr 9, 2014 10:35 AM
Franko72
32
Mar 18, 2011 08:31 AM
