4x4 hub replacment
Old Mar 14, 2011 | 02:42 PM
Franko72's Avatar
Franko72
Molon Labe
4x4 hub replacment
My bosses 01 F350 4x4 is making some horrid grinding noises in the front axle, He claims its the bearings and hubs. I'm not there to look at it, but Its my job to tear into it tomorrow.
Being a 2wd guy I have no experiance with hubs, he mentioned getting "Warn" replacment hubs.
What do you guys recommend? are the Warn hubs a good choice, are there any special tools we will need to do bearings and hubs.
Any help is appreciated, I already installed 3 brake backing plates on his boat trailer backwards last friday.
I have to redeem myself tomorrow...
Old Mar 14, 2011 | 02:49 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have a look at this Frank. LINKEY.
EDIT: If he has a dually, I took the spacer off to get to the snap ring.
Old Mar 14, 2011 | 02:52 PM
Franko72's Avatar
Franko72
Molon Labe
Thank You Rick ole buddy...
That will come in handy
Old Mar 14, 2011 | 02:53 PM
Franko72's Avatar
Franko72
Molon Labe
Yep its a dually, wheel spacer you mean?
Old Mar 14, 2011 | 02:58 PM
miller_feed
Yep. The spacer for the wheel. You may could do it without taking it off, but I found it easier to take the spacer off. Get a 2x4 about 24" and slip it between the lugs to hold the rotor from turning while taking the nuts off the spacer. Let me know if I can help, or get you a 4x4 and learn.
Old Mar 14, 2011 | 03:05 PM
Franko72's Avatar
Franko72
Molon Labe
Cant I just get the 4x4 sticker instead.... I think I'll get plenty of practice on his truck. he works it pretty hard.
I would rather have a two speed rear end, so I could have a granny gear for backing trailers, and a good hwy gear for mileage.
Thanks for the tip, and keep an eye on this thread tomorrow, I'm sure I'll have a few questions...
Old Mar 14, 2011 | 05:39 PM
big poppa's Avatar
big poppa
Good luck Frank, looks like a cut and dry install although I just had mine done today, trying to stimulate the economy, well, no time and short on tools really.
Old Mar 14, 2011 | 07:27 PM
Franko72's Avatar
Franko72
Molon Labe
Thanks Mike, I'll let you know how bad the job is tomorrow.
Old Mar 14, 2011 | 08:00 PM
Night Crawler's Avatar
Night Crawler
are you doing the hub/wheel bearing asembly or just the locking hub's? You will need the special nut socket for the hub bearings.
Old Mar 14, 2011 | 08:24 PM
SpringerPop's Avatar
SpringerPop
I don't understand this.
There is a special nut socket for the rears, but this is for the fronts.
Pop
Old Mar 14, 2011 | 08:27 PM
Franko72's Avatar
Franko72
Molon Labe
Just doing the front hub and bearings as far as I know.
If I need a tool, my boss will go buy it I'm sure.
Old Mar 14, 2011 | 09:30 PM
Night Crawler
Pop
sorry, long day in the wind. Front's are bolted rear has the nut.
Old Mar 15, 2011 | 09:36 AM
Franko72's Avatar
Franko72
Molon Labe
Ok, they are apart. Boss is on the fence if he wants WARN manual hubs or stock Ford hubs. Dealer wants 2x the cost of the Warns.
I looked on Eds site, but I know hes out recovering. Plus I couldnt find what I was looking for anyhow.....Anyone Have a dealer connection?, or can lead me to a site sponser that can get the Stockers for less than the local Dealer.
If he decides on Warns, Clay will be the man.
Old Mar 15, 2011 | 09:45 AM
Night Crawler
Clay, Rifraf has Warns both standard and premium, also if your in a bind, sometimes Advanced carries the warns, ballpark of $200 for both. yeah I would not go back with stockers, cheap design I think
Old Mar 15, 2011 | 10:59 AM
Franko72's Avatar
Franko72
Molon Labe
We may be putting it all back together and calling a hook, Looks like the axle bearings are shot...
Here is a video, let me know what you think.
YouTube - F#50 front axle bearing slop
