I have a Van Norman model 333. The spindle reduces down at one end to 1" where a brake drum is clamped. The other end had a large nut. I removed this and it was a shaft that extends to the other end with threads on the end.
I am thinking that the shaft would snug up the 1" end in a taper but I can not tap it out. Any help would be appreciated. The 1" portion is larger where it goes inside the spindle.
Are you sure it is not a 303? Do a search, Google had a lot of places to check for info, I also tried Van Norman Equipment Co, (bought by Kwik-way in 2001) I have done this in the past looking for owners and parts manuals and have had real good results. Good Luck, George The reason I say 303 is that there didn't seem to be any model 333.
It is a model 333. I saw another one for sale on the web. I am pretty sure the 1" portion is solid metal where it becomes larger. I thought about it being threaded but I can't see why they would do that. Another guy said to unscrew the shaft just a couple of turns and then hit it with a hammer. I don't want to risk damaging the threads.
