Sponsored by: Real Truck
Bearing
Old Oct 7, 2014 | 01:47 PM
DontUluvFod's Avatar
DontUluvFod
Bearing
My vehicle had a shudder which felt like driving over a rumble strip. It would usually occur after hitting a small bump at around 35 mph and hearing a clunk underneath. The shudder lasted just a few seconds. Checked the whole steering, suspension, chassis, drivetrain, u-joints, rear e-brake shoes etc. Finally found that the RF axle shaft could be moved up and down excessively in the steering knuckle. Removed axle shaft, R&R u-joint, vacuum hub seal and the torrington bearing in the hub. (used to call it a spindle bearing) There was a little bit of wear into the stub shaft where the spindle bearing rides. That removed the play from the axle when it was all re-assembled. I was very happy until about a month later when it started doing it again, but not as bad as it was originally. I think maybe the stub end of the axle shaft needs to be replaced due to the wear in it. I don't want to just throw a somewhat expensive part at it without some input from anyone who is familiar with the "superduty shudder".
Old Oct 9, 2014 | 06:28 PM
Ski1982's Avatar
Ski1982
I know you said you checked everything, but the clunk and rumble strip descriptions sounds like an upper ball joint.
Nicmike
Dec 13, 2024 05:39 AM
67highboy
Apr 22, 2018 10:20 AM
flyingek
Aug 19, 2009 08:54 AM
lalevant
Jun 12, 2009 11:47 PM
Technitom
28
Apr 22, 2008 11:00 PM
