Help need spindle
Old Apr 11, 2014 | 01:38 PM
torpedo51's Avatar
torpedo51
Help need spindle
I've got a 1973 F-250 4x4 with Dana 44 axles and 8 bolt hubs with drum brakes.
When replacing a noisy bearing on the front, I discovered that its spindle was ground. I can't seem to find a replacement.
I've taken measurement from the good spindle on the other side. The outboard journal is 1.625". The inboard journal is 2.000"
The part number on the good spindle is: W25789X S3T31 I can't find this part number anywhere - I don't know who made this part.
Help!
Old Apr 11, 2014 | 01:40 PM
brinker88's Avatar
brinker88
Here ya go
Spindle Dana 44, 1978 - 79 3/4 Ton
Edit- **** that looks like it only fits 78/79
Or this....They both have the same measurements you gave...
http://broncograveyard.com/bronco/i-...e-3-4-ton.html
Old Apr 13, 2014 | 11:58 PM
torpedo51's Avatar
torpedo51
Negative. Mine is shorter. Updated specs:
Overall length: 6.250"
Overall width (flange): 4.750"
Outer journal: 1.625"
Inner journal: 2.005"
6 holes in the flange
I could use help identifying the vendor from the part number provided.
Thanks
Old Apr 14, 2014 | 02:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The Dana (Spicer) part number on the good spindle is: 25789-X
C7TZ-3105-E .. Spindle / Dana (Spicer) ID number: 25789-X / Obsolete ~ No Ford dealer or obsolete parts vendor has any.
1967/72 F250 4WD with 3,500 lb. capacity Dana 44F-6HDF & Dana 44-6CFHD front driving axles.
1973/75 F250 4WD with 3,500 lb. capacity Dana 44 with part or full time drive, with or without P/S.
Old Apr 14, 2014 | 10:55 AM
torpedo51's Avatar
torpedo51
If the part is obsolete, I'll need some direction on how to change the spindle and bearings while all other components remain the same.
Anyone?
Old Apr 19, 2014 | 08:55 AM
torpedo51's Avatar
torpedo51
For the benefit of others:
SIX STATES DISTRIBUTORS is currently manufacturing these obsolete spindles with a matching part number. I've purchased and installed one.
Thanks to all for the help.
Hogtrapper
19
Mar 25, 2015 12:34 PM
78F-250Lariat
Oct 5, 2014 10:07 AM
miottimouse
Jan 8, 2014 08:36 AM
EL_JEFE32
Sep 28, 2013 07:20 PM
