Fe446
Old May 21, 2004 | 10:54 PM
shrike's Avatar
shrike
Fe446
I have been getting info together to build a 410 motor, but have just read a post by GTEX about a 446 motor, this sounds more appealling than the 410, I know I need a 428 crank and different pistons, but what else do I need to make this happen, I lost a finger in a work accident the other night and about all I can do at this time is plan this project out. thanks in advance for ya'lls help.
Old May 21, 2004 | 11:07 PM
Randyb12's Avatar
Randyb12
Sorry to hear about the finger.
4.08" bore and a 4.25" stroke. This will get you 445cid
Custom pistons will be needed..
Old May 21, 2004 | 11:12 PM
Scouder's Avatar
Scouder
Originally Posted by shrike
I lost a finger in a work accident the other night....
If you are a proctologist or a dentist I'm gonna lose it!
-Scouder
Old May 22, 2004 | 12:23 AM
shrike's Avatar
shrike
no gynecologist
Old May 22, 2004 | 06:26 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Sorry to hear about your Finger...Ya have to watch playing around those happy Clams!
Old May 22, 2004 | 07:56 AM
gtex's Avatar
gtex
My FE446 is actually 4.125" stroke SCAT aftermarket crank in a .020" over 428 block. So, 4.125" stroke and 4.15" bore.
Old May 22, 2004 | 12:57 PM
Randyb12's Avatar
Randyb12
I think he has a 390 block. I was trying to get him close with what he has. Those 428 blocks are hard to find and expensive.
Old May 23, 2004 | 07:40 AM
shrike's Avatar
shrike
randyb12 I have a 360 block, anyhow thats what the vin tells me, "Y" is a 360 right? Would going 446 thin my cyl walls out? all I want to do is spank this guy at the strip who has a 69 chev w/built up 350. One way or another he's going down. thanks for the info. shrike
Old May 23, 2004 | 08:16 AM
gtex's Avatar
gtex
Shrike,
The 360 and 390 have teh same block/bore at 4.05". You can probably go up t0 .060" over, but should only go as far as needed to rebuild. That's typically .020 or .030" over bore to clean up the cylinders.
Then, depending on your budget, you can pick your stroke. A 390 crank is 3.78" stroke, a 428 crank is 3.98" stroke, and there are aftermarket cranks for 4.125" and 4.25' stroke like Randy mentioned.
You can make probably make a 360 that will run with that Cheby, depending on what he's got. A well built 390 would be a challenge for most any 350 in a truck.
Old May 23, 2004 | 03:13 PM
Randyb12's Avatar
Randyb12
Like Greg said a 360 and a 390 share the same block and bore size. the only difference is the stroke. A 390 crank (3.78) is easy to come by., 428 cranks (3.98) are more expensive but still affordable. A 428 crank in a 0.030 over 360 block will get you 416cid. A aftermarket crank at 4.125 stroke will get you 432cid. And as memtioned above a 4.25" crank will get you 445cid.
The cost of the big cid engines get up there with custom pistons and the 4.125 and 4.25 cranks get up around 700 to 1000 dollars.
Hope this helps.
Old May 23, 2004 | 04:22 PM
gtex's Avatar
gtex
Hope this helps.
Don't forget the $500+ for a set of BBC rods if you go with the aftermarket stroker cranks.
Old May 23, 2004 | 06:32 PM
Randyb12's Avatar
Randyb12
Greg
Thanks for catching that omission.
Old May 24, 2004 | 08:49 PM
shrike's Avatar
shrike
what about pistons? do you have an after market source? I take it that the 360 or 390 pistons won't work.
Old May 24, 2004 | 10:00 PM
Randyb12's Avatar
Randyb12
If you use the 428 (3.98" stroke) you can get pistons for a Mercury 410cid engine. Because that is what you would be building. For the bigger cranks call around. J.E and Wiseco as well as Keith Black and many others can make any thing you want.
Old May 25, 2004 | 08:15 PM
shrike's Avatar
shrike
thanks guys, I think I have something to work with now, and as far as the finger goes, it was re-attached, went to the ortho today and I have feeling in it so thats a good sign the surgery worked. Thanks to all, Later, shrike
