Running cable through firewall.
Old May 21, 2004 | 08:53 PM
svn2002s's Avatar
svn2002s
Is there a hole in the firewall to run a thick power cable into the cabin ala F150. Finally I am replacing Ford's crappy 'audiophile' system in my 03 EB. (BTW this is the only thing where Ford messed up, everything else is A+)
Old May 21, 2004 | 08:58 PM
HomerWinzlow's Avatar
HomerWinzlow
You can make a hole just about anywhere you like.
Old May 22, 2004 | 07:57 PM
triton_2002's Avatar
triton_2002
There's already plenty of holes thru the firewall, just gotta look. Usually the drivers side is easier, look for black rubber plugs under the dash above the gas pedal. There's some plugs under the door sills too.
Old May 22, 2004 | 07:59 PM
99expyTN's Avatar
99expyTN
There is a black rubber plug in the firewall. From the engine compartment, it is on the drivers side (to the left of the brake fluid resevoir). You can either remove the plug or cut a hole in it.
MasterMarine
Escape & Escape Hybrid
28
May 14, 2013 08:08 AM
jostw8
6.4L Power Stroke Diesel
Feb 24, 2012 05:19 PM
Steves55
Oct 27, 2010 03:43 AM
olelepoint
18
Dec 15, 2009 08:44 AM
aw56
Jan 4, 2004 03:24 PM
