Stupid brakes!
Also, before winter I tried and tried to change out my O2 sensor. The nasty one on the pass side. I could not get anything on it. Any more advice? It's literally frozen in there. I'm in Kansas City so we do get snow, salt, rain, etc.
Thanks,
Mike
Smitty
BigMan69
Anyways since there is now air in the system, don't forget to bleed the brakes when you get it all put back together.
Glock
For future reference you really don't need to take the brake line loose from the caliper, the unit will lift entirely clear of the rotor. Use a wire coat hanger to support the caliper by "hanging" it off the coil spring (don't let it hang by the brake line as that can damage the line).
I live about 5 minutes from Prairie Village...if you get in a bind tomorrow I'd be happy to help... just drop me an email (gk@everestkc.net) and I can give you a call.
Good Luck,
Gary
The passenger side actually came off pretty easy. Don't get me wrong, I still had to beat the crap out of it. Now I have to run down to the store to get a c-clamp. I swear I've bought more tools doing this darn thing! The driver's side I took to work and was able to use a clamp there. Ah well. I just hope it stops once I get it all back together!!
Thank you all for your suggestions. The passenger side went very smoothly. Bled the lines and took her for a spin and it was great! Not even a squeak! For future reference here's what I learned:
Start by having a LOT of PB Blaster and a REALLY BIG HAMMER!!!
1. Pull off the wheel.
2. Use a Torx-45 to remove the caliper and hang it out away from the rotor. There are 2 bolts to remove. One on top and the other on the bottom. Use a wire or something to hang the caliper so that you're not hanging it from the brake line.
3. Remove old brake pads. They should slide right off.
4. If you need to remove the rotor, GOOD LUCK! I had to remove the brake pad holder bracket thing (guys, can you help me out with a name here?) and then beat the crap out of the rotor till it fell off. If you need to remove the bracket, it's 2 18 mm bolts. One on top and one on the bottom. Be prepared to apply a lot of leverage.
5. You may also need to remove the lugs. If so, just tap them through.
6. Clean everything really good!
7. Once the rotor is off and you have strength in your arm again, replace the lugs and rotor and apply a light coating of anti-seize to the contact surfaces of the rotor.
8. Reattach the brake pad bracket if removed and slide in the pads. Use a little caliper grease on the back of the brake pads. NEVER on the pad itself.
9. Push the caliper pistons in with a c-clamp in order to make room for the new pads.
10. Slide caliper on and replace bolts. This can be a little tricky as you have to get the prongs at the top and the bottom to slide into the metal slides.
11. Replace tire and tighten up lugs really good.
12. Bleed system starting with wheel farthest away from the master cylinder and continue working toward closest.
13. Give her a test drive!
This is pretty much for my future reference in case I have to do it again I'll have some guidelines. But maybe some other first timer will benefit from them too. You pros let me know if I can add or change something to make it better.
Now onto the MAF and the coil!
Thanks again you all!!
Mike
Glad you got it fixed.
Glock
