Replacement engine for 67 f100 - ideas ?
Old May 20, 2004 | 11:49 PM
denisontexas's Avatar
denisontexas
I am the proud owner of a 1967 F100 with a sick engine.
The original engine is a 360 and it has a bad knock in the lower engine but still runs (not going to keep testing it).
I'm an old time ford truck guy (had a 51 F1 and have a 56 f100), but I'm not familiar with the 360 whatsoever and I'm looking for advice from those that have made the journey.
"In general", is a 360 worth rebuilding or should I put the same amount of money in a 390, 428, etc.. ?
Meaning... are they good engines and were they well designed ?
Do they hold up as well as the others that Ford made ?
My current plans are to just rebuild it (Crank, bearings, etc..) but if they are not considered to be good engines, I may be better off builing a 390 or 429 Boss
Ideas / Suggestions ?
Thanks
Mike
Old May 20, 2004 | 11:52 PM
ramboss429's Avatar
ramboss429
I'd go with a 5.4L myself I've always wanted to transplant a Lightning engine into an old pickup just to be the first to do it. Thats just me.
I'd go with the 390 option. Although a 429 Boss would be a smokin engine
Old May 21, 2004 | 11:06 AM
67and71_Carl's Avatar
67and71_Carl
Denisontrexas,
I don't think the engine is a 360 if it is the original engine. It would be a 352 if it is the original. That may or may not affect your descision to rebuild it as a 390. I've heard people say that the mileage is about the same between the 352-360-390, so they generally go for the additonal torque of a 390. The guys in the FE Forum are a vast wealth of knowlegde on this subject. You may want to toss a line out there.
Old May 21, 2004 | 05:48 PM
Fritolay's Avatar
Fritolay
two things first go talk to the guys in the fe engine forum (332,352,360,390, and 428) they are a great help and may be able to help you decifer the knock.
second yes the 360 is worth rebuilding if it is the original motor it has 37 years on it if that isnt durable what is? and also a 360 and a 390 are practically identical engines the only difference is the crank and rods, which can be bought from several parts stores.
if you are looking to really up the horses and have some fun with the engine edelbrock makes a nice set of alluminum heads for this motor, and a couple nice intakes as well, if you have one on your 360 it will fit perfectly on a 390 same block heads and so on.
also there are a few modifacations you should do to the block while you have the engine out, and if you are going to upgrade the heads also consider upgrading the rockers, there are complete shaft mount assemblies avbailable for this motor.
just some thoughts hope this helps
Old May 21, 2004 | 07:39 PM
rusty70f100's Avatar
rusty70f100
No matter which it is, 352 or 360, yes, it's rebuildable. If it's a 352, bore it .050" over and build a std. bore 390. If it's a 360, bore it .030" over and build a .030" over 390.
Get the 390 crank and rods, a good place to get 'em is DSC, or your local junkyard. I'd try the junkyard first to save some money.
Get some aftermarket pistons, TRW makes some great forged pistons, but others are cheaper. Get some with a 1.776" compression height so you end up with a decent compression ratio.
Port the stock heads that are on it, get a good cam like the Crane 343941, get a 4-barrel intake like the Performer RPM, throw a Holley 600cfm carb on it, and you're golden.
Edit: You could also make a 410 by using the 390 rods, and a 428 crank. I think that'd be the way to go if you can afford the 428 crank. Get some 1.680" compression height pistons for it.
Old May 21, 2004 | 08:30 PM
michaelbrainardatwor's Avatar
Hey...why not a 350 or 454!!! Ok..who is first in line to plant their boot in my rear-end? HAHAHA Sorry guys...the whole idea of getting my boat out tomorrow has got me thinking Mercruiser and Bow Tie....
Old May 21, 2004 | 10:56 PM
rusty70f100
--SMACK!--
Sorry, didn't want to soil my boot.
Old May 22, 2004 | 02:59 PM
fordbeast_80's Avatar
fordbeast_80
Depending on what you plan to use the truck for, a rebuilt 390 should be stout enough for most truck duties.
Old May 23, 2004 | 11:31 AM
dnmyoda's Avatar
dnmyoda
I have a 69 with the 360 i wouldn't trade it for anything i just rebuilt it last year with everything but the proformer heads from edle. but the thing has more than enough power now and for fun you can put 5.9 or 360 v-8 on the outside of your truck and make the dodge guys cringe as you blow their doors off
Old May 23, 2004 | 03:26 PM
mlf72f250's Avatar
mlf72f250
Depends on what you want to do with it.
If you just want reliable transportation, rebuild the 360 and keep it stock.
It you want something warmer, do a 390 and keep it close to stock.
Warmer yet? Try a 390 with PITA hot cam, knuckle-burning headers, and the works.
Still not hot enough? Get a 460.
Trish Butcher
Sep 25, 2016 07:07 AM
bigreed91
Apr 28, 2016 11:38 AM
74f100sc
15
Feb 23, 2016 11:26 PM
TheGermanGuy
Jan 31, 2016 02:06 AM
1975 f150 360
16
Jan 18, 2009 11:04 PM
