What is a stroker engine, how do you "stroke" it?
Old May 20, 2004 | 08:46 AM
calazo's Avatar
calazo
Unhappy What is a stroker engine, how do you "stroke" it?
Pardon the ignorance, I've heard about stroker engines, what are they, hw do you "stroke" an engine?, can this be done at the machine shop?
Old May 20, 2004 | 09:25 AM
Mike G's Avatar
Mike G
Is a quick synopsys, the "stroker" comes from the use of a crank with a longer stroke. This means that the centerline of the crank to the centerline of the rod journal is increased.
--Mike
Old May 20, 2004 | 09:18 PM
Camille Marquis's Avatar
Camille Marquis
get some 4x4 mags and read even hot rod features stroker motor rebuilds
Old May 25, 2004 | 02:33 AM
fordeverpower's Avatar
fordeverpower
yeah a stroker is achieved from more crank throw. You should check into a 393 or 408 kit for the 351w.
Old May 28, 2004 | 11:33 AM
calazo's Avatar
calazo
Question Could I turn a 351W to a stroker with 400cid parts?
Guys, could I use a 400 crank to turn a 351W into a stroker; what else would be needed? i.e. rods, pistons? thank you. What advantages come from "stroking" the above engine? what about fuel economy, thanks....
Old May 28, 2004 | 01:35 PM
Mike G's Avatar
Mike G
No... The 351w and the 400m do not share the same crank journal size. I believe you would have to have the 400 crank turned down to fit the W block. Increasing the "stroke" will give increased lower end torque, and overall HP as well. If you purchase a stroker kit, you get everything you need but may also need to clearance the block to clear the extra throw in the reciprocating assembly. The good thing about the W stroker kits is that they are "relatively" cheap.
--Mike
wyoming4x4
Sep 2, 2014 04:30 PM
jmono
28
Jul 1, 2006 11:52 AM
how2fish
1966 - 1977 Early Broncos
Nov 29, 2005 11:28 PM
Madmike33
Mar 18, 2005 07:45 PM
turbonatr
May 1, 2003 07:13 PM
