abs light coming on
Old May 19, 2004 | 11:37 AM
gbeach's Avatar
gbeach
abs light coming on
my abs light is coming on at startup, but i can turn the truck off and back on again and it will go away. it is doing it intermittenly, not all the time.
93 f250 7.3 idi. i do need to do my rear brakes, but i haven't noticed any braking problems. any ideas
Old May 19, 2004 | 02:00 PM
tsc's Avatar
tsc
sounds like a sensor is going on you. Next time, swing over to auto zone and have the code pulled.
Old May 20, 2004 | 12:30 AM
351M's Avatar
351M
First place to check, apply to dodge ford and chev, the plug on the rearend for the sensor gets hammered with rocks and other stuff, they are known to go and 90% of the time it is the last thing people check.
Old May 20, 2004 | 08:02 AM
gbeach's Avatar
gbeach
thanks guys i'll check it, do you know exact location
Old May 20, 2004 | 01:15 PM
351M's Avatar
351M
Right on the top center of the rearend there will be a black plug. If it is bad the firs and cheapest thing is to unplug the wiring that comes from it where it hooks up on the frame and test it, usually that part of the harness is cheap to replace.
Old May 28, 2004 | 04:56 PM
WallaceC's Avatar
WallaceC
Does your cruise controll still work? There is a sensor(on the rabs) that comes from the auto tranny to the rabs valve. Mine died and caused the light ABS light to flash and I lost cruse controll as well. This apparently causes the cruise to kick out when applying brakes, dunno why the ABS light flashes when it dies.
Wallace
Old May 29, 2004 | 11:26 AM
roamer37's Avatar
roamer37
Check your brake fluid level if its low it will turn on the light for RABS
Old May 30, 2004 | 10:11 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Troubleshooting RWAL Systems, Bill Williams, Brake & Front End, September 1999
ANTI-LOCK BRAKES | Kelsey-Hayes RWAL Anti-Lock Brakes
Here is the thread where I fixed my ABS warning:
antilock brake light
guitarmark
Nov 30, 2012 03:51 PM
fairlaniac
Dec 12, 2011 06:37 AM
edub32
53
Feb 5, 2006 09:05 AM
westladog
Oct 25, 2005 06:47 PM
mvlr5000
Aerostar
Aug 8, 2003 05:06 PM
