weight difference between bumper pull and goose neck?
Old May 19, 2004 | 08:48 AM
johnman's Avatar
johnman
i was wondering if a f250 sd crew cab was rated to pull for instance 11,000 #
would that rating be higher if it was a gooseneck or fith wheel?
thanks!
Old May 19, 2004 | 09:01 AM
johnsdiesel's Avatar
johnsdiesel
Chances are if you're pulling a fifth wheel or gooseneck with an F250 CC 11K is too much. About 20-25% of that weight is going to be on the truck, which would be a minimum of 2200 lbs. Go weigh your truck and subtract that from the 8800 GVWR and you'll be surprised how little payload you have left.
Old May 19, 2004 | 09:11 AM
NoMo's Avatar
NoMo
To give you some idea of the weight of an F350 SRW CC 4x4 w/V10, mine weighed 7500 lbs. with a full tank of gas and me & wife in the truck. As the F250 & F350 SRW are basically the same, this would only leave 1300 lbs for pin-weight for goose-neck on an F250. The SRW F350 has 2400 lbs available payload capacity. The F350 dually would have even more!
As for your question, regardless of tow method, the GVWR and GCWR are set by the manufacturer. Goose-necks & fifth-wheels are the same. Tag-along (bumper pull) weight ratings are generally lower than goose/fifth ratings. However, a "bumper-pull" trailer only puts 10-15% of the weight on the truck. So, with an F250 CC, it's possible to tow more (without exceeding GVWR) with a bumper-pull trailer than with a goose-neck/fifth-wheel. However, I think tag-along trailers are much less stable than goose/fivers.
Old Dec 16, 2004 | 12:04 AM
RDPrimeaux's Avatar
RDPrimeaux
if you are asking if there is a difference in the weight rating between a 5th and a GN, no
trucks are rated higher using a 5th/gn, as opposed to bumper pull.
what the rating is for your truck i do not know
i consistantly tow over my truck's ratings, howver, i am aware of that fact, and make sure the trailer brakes are 110%
Jake4809
6.7L Power Stroke Diesel
Sep 20, 2014 10:01 AM
wildstang
Jun 17, 2013 08:51 AM
Daveyf15096
Jun 20, 2011 05:05 AM
honeyb
May 9, 2009 04:29 PM
AJ99
Nov 24, 2008 12:30 AM
