2 speed rear
Old May 19, 2004 | 06:02 AM
stang88's Avatar
stang88
2 speed rear
any 2 speed rear ends out there for a 10.25????? i seen one in a dodge pickup thought it was pretty cool
Old May 19, 2004 | 11:18 PM
SoCalDesertRider's Avatar
SoCalDesertRider
None that I know of. Typically, a 2speed rear end isn't something that you add to your existing axle, it's a different axle. You can put a Gear Vendors or US Gear over drive or under drive unit on the back of your transmission to use a splitter the way you would use a 2 speed rear. They are about $2500. Check out www.gearvendors.com . Or you could change the transmission to one with a granny gear or an overdrive, depending on which way you're trying to go (or a ZF 5speed, which has both). That's probably the cheapest option.
Fabman54
Large Truck
Jul 15, 2012 12:12 AM
bunchgrass
Large Truck
Sep 19, 2011 03:12 PM
knip4x4
Oct 5, 2009 09:46 PM
countrymike
Dec 12, 2004 02:51 PM
enduringexplorer
Mar 15, 2002 11:54 AM
