Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 5 speed
Old Sep 19, 2011 | 12:21 AM
bunchgrass's Avatar
bunchgrass
F600 5 speed
What trans makes were the 5 speed manuals (w/ 2 speed rear) that were likely to come with the F600? Any 5 speed trans that should be avoided?
Old Sep 19, 2011 | 02:06 AM
85e150's Avatar
85e150
A couple models of Clark, direct and OD, and a NP542 possibly.
What year?
Post the VIN and all the codes off the info plate for better answers.
As long as it shifts, and doesn't pop out of gear, whine and growl when it shouldn't, it's as good as any.
Old Sep 19, 2011 | 03:49 AM
big job's Avatar
big job
5 speeds
I suppose this would relate to the year or years of the trucks. Mostly
in the fiftys all atleast I know of were Clarks 5 spd. 4spds mainly
Warners then getting in the sixtys they used a lot of Spicers med and
HD. then N Process. My guide has been Clarks 1st & reverse being to
the right with rev up to the glove comp. Spicer 1st to the left with rev
up to the instrument panel. Im pretty sure of this cause I have all
four of these 5sp trannys. I have not had any issues with either one.
Old Sep 19, 2011 | 11:55 AM
bunchgrass's Avatar
bunchgrass
Thanks - I know it would help if I had the VIN stuff but it's in a truck I'm going to look at and that's had the tran replaced. Now, the new tran is still acting up (hard to shift between certain gears ....), so I just wanted to check if there was a trans to AVOID. BTW - this is a 5+2 in a 1991 F600 6.6L rig I've mentioned in a previous thread.
Thanks again.
Old Sep 19, 2011 | 03:12 PM
85e150's Avatar
85e150
Sorry, didn't recognize the name--seller is getting that fixed, right? Difficulty in shifting could be synchros or could be a clutch issue.
AFAIK, IIRC, never seen any comments here about 5 speeds to avoid by model etc, just some common problems with the NV4500 in Dodges, and the usual "worn out" condition of high-mile units.
charlesecarter
13
Nov 27, 2025 06:10 AM
mabc926
Jun 12, 2010 06:05 PM
charlesecarter
1978 - 1996 Big Bronco
Dec 9, 2007 10:06 PM
FlameOut
1983 - 2012 Ranger & B-Series
Jul 17, 2007 06:31 PM
46yblock
1947 and Older Ford Trucks
Sep 23, 2004 11:02 AM
