converting an electronic ignition to points
Old May 18, 2004 | 09:11 PM
matt reed's Avatar
matt reed
How do you change an electronic ignition over to a points engine in a 79 F250?
Old May 18, 2004 | 09:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Why in heavens name would you want to???
Old May 18, 2004 | 11:04 PM
ashvalentine's Avatar
ashvalentine
You get a replacement points based distributor. Mallory makes a dual point one.
You'd have to disconnect the ignition voltage wire from the module wiring and wire it straight to the coil, and then wire the coil straight to the distributor.
ash
['Not all that much to it.']
Old May 19, 2004 | 09:31 AM
73Custom's Avatar
73Custom
I'm not sure I understand what you are trying to accomplish... Are you installing an older engine (with points dist) into your '79? If so, then just remove the dist from the '79 engine and install it into the 'new' motor and all is good (as long as both are the same type engine). If you don't have the '79 engine, just get correct dist from parts store - some will even take the points dist as core for electronic dist...
I'd suggest not changing the '79 over to points, the Ford Duraspark II is a very strong dependable system that is simple to repair. Many people upgrade from points to Duraspark II ignition (I did).
Marty
mla
Feb 1, 2009 09:51 PM
BIIman
19
Nov 15, 2006 04:11 PM
novadragman2005
30
Feb 16, 2005 03:20 PM
qman
Nov 14, 2004 06:37 PM
rebocardo
Jul 5, 2002 06:46 AM
