raidator drain?
Old Dec 22, 2001 | 12:52 PM
Latebloomer's Avatar
Latebloomer
raidator drain?
I have a 1984 250 4x4 diesel.I have ordered a owners manual which hasn't arrived yet.I am wanting to drain and flush cooling system.I need to know how many drains and where they are located.
Thanks for any help...
Old Dec 22, 2001 | 01:01 PM
Latebloomer
raidator drain?
Sorry ,I ment to say radiator.
Old Dec 22, 2001 | 02:41 PM
BigDeezil58's Avatar
BigDeezil58
raidator drain?
Well, you could always use the "Flat Rate" drain method and just pull off the lower hose. If you are going to replace the hoses(recommended), just cut the sucker. Don't do it when it's hot for obvious reasons... ......unless you are REALLY fast. It's not even messy if you have a big enough drain pan. I got sick of broken/leaky pet*****, so this is my preferred method. Just my $0.02. Happy Holidays:-X12
Old Dec 22, 2001 | 04:38 PM
Latebloomer
raidator drain?
One more question,is there a place to drain the block?I drained radiator and got about 20 or so qts.At the parts place there book showed 31 qts.So there is somemore in there somewhere.
Thanks .
Old Dec 23, 2001 | 09:41 AM
powerstroker250's Avatar
powerstroker250
raidator drain?
There are drain plugs on each side of the block near the rear of the engine. Also, blow out the heater core with air.
Les
Old Dec 24, 2001 | 11:26 AM
Latebloomer
raidator drain?
Thanks for the help fellows.
Latebloomer
Old Dec 25, 2001 | 11:49 AM
powerstroker250
raidator drain?
mprsox
Jul 28, 2019 01:12 PM
DMTR
Aerostar
31
Jan 31, 2014 06:31 PM
riverbottom
1997 - 2003 F150
Nov 24, 2009 06:29 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
FX4dude
Oil & Lubrication
Mar 13, 2004 08:36 PM
