Pyro Install on 2004 F350 6.0
Daryl....
Know your teasing, but it is a New member !!!
And he may not know your just full of
hot air
Welcome Super duty !!! We tease a LOT around here
The bd X Monitor is a good unit !
You can get either the 3 mode or a 2 mode with EGT and Boost or... lot's of options
I too like my 03 Ex's grab handle - but even with the X monitor if it's not already trimmed it make take a slight cup to fit under the handle...
Give our buds Motorhaven a call - they be good guys and gals !
and here's some info on the unit http://www.dieselperformance.com/for...Gauges&tt=ford
hot air
on
Yes, I was teasing, hence the smiley. Please don't take it personally Super Duty.
The question is asked so frequently though that I'm thinking of writing a macro so something so I can just press a button and post a response with the info.
Maybe we need a sticky with a FAQ for gauge, exhaust, and other favorite options. Should probably also include a link to installation instructions with photos for the pyro probe in both pre and post turbo positions.
The site has a great search feature, but for new users, perhaps the sticky FAQ would be a good starting place.
Geeezzz, can't a guy ask an innocent question around here without takin' 40 lashes Actually, I knew he was kiddin. I don't have much luck with the search function yet on this site...still learnin how to get it to work. Checked the BD-Power web site and the picture of the pillar mounted unit wasn't large enough to really see how it looks mounted. The dash/steering column image was large size. That application, I must say, isn't too attractive IMHO. Best look seems to be the pillar pod but then, there goes the grab handle. Any other gauge location ideas?
weLL !!! so you don't think ours are pretty, huh ?!?!!?
but you do paint it to match the dsah and it blends right in and all you really see is the display....
Again - call Motorhaven tomorrow, they can give you some good ideas !
Some have put them in the cubby hole near the gearshift,
some have mounted on the dash - Check Choctaw Bob's gallery -
think he did his that way...
good luck !
good luck !
on
Daryl
Originally Posted by n6nfg
Picture looks good, that is where I figured you meant. I was concerned about having the probe too close to the socket access for the bolt above and slightly left, might have to remove the probe if this bolt ever needs to be removed.
Whose gauge pod do you have? I was looking for a dual pod, and it looks like Motorhaven only sells a triple, not a dual. Whose gauges are they, they don't look like banks or isspro.
What path did you take into the passenger compartment, and does the probe wire disconnect from the probe for routing purposes?
So many questions, so few answers
Ask all your questions here. Someone will assist. I'm sure someone will make funnies also.
on
A number of people have drilled and tapped successfully without removing the manifold. At least their trucks are still running fine after the operation.
There are a few techniques that I've seen in posts on the subject. The first was to have the truck idling while drilling. The idea is that this puts a positve pressure inside the manifold and blows out any chips that otherwise might fall in the manifold as you penetrate it. Same for tapping.
The other method was to use a shop vac to apply suction while drilling and tapping and then to take a Q-tip and try to capture any chips that might have fallen inside the manifold. Finally follow up with a magnet to try to remove them.
I just took my manifold off and did it all on my drill press and work bench. That way I was able to inspect the manifold and determine just where I wanted to put the hole and probe. No worry about chips - and there were a lot of them. Just used the air compressor to blow the manifold clean before reinstalling it.
If you do go the remove the manifold route, jack up the truck and remove the left front tire. Use plenty of safety stands of course. The manifold itself was very easy to unbolt from the block. The only hard part was the two bolts on the rear that secure the manifold to the pipe that feeds the turbo. There isn't a lot of clearance to get to the nuts on the back side of those bolts.
Either way you go, the pyro probe and meter is a nice addition to the truck.
Daryl
Daryl
KJNDIVER
04-13-2014 02:59 PM
andersda437
Computer Chips & Tuners
08-27-2004 07:19 AM
