Uphill vs. downhill cold start problem
Old May 17, 2004 | 12:58 PM
dpekin's Avatar
dpekin
When I park the truck downhill it cold starts like a champ. When I park it uphill it doesn't. It will cough then act like it's starved for fuel for 15-20 seconds of cranking. Then it will start rough and smooth out after another couple of seconds.
It always starts fine when it's warm.
Has anyone heard of this?
To diagnose it further I'm going to switch to the other tank and park it uphill to see if it reacts the same. Maybe it's the in-tank fuel pump not getting the fuel up to the injector pump.
Dave
'94 F-350 Crew Cab
Old May 17, 2004 | 01:02 PM
Thunderbox's Avatar
Thunderbox
You are experiencing a problem with the fuel filters. There is a fitting on the fuel filter which has a small orifice in it. If you park on an uphill it will bleed the fuel back to the tank and cause long cranking and poor running at first. Filling in the hole with some brazing will eliminate this problem. There is a Ford TSB out on this exact problem.
Old May 17, 2004 | 02:18 PM
dpekin's Avatar
dpekin
Where is this vent hole? How do I find the TSB? I suppose you could plug it w/ a variety of materials, FormaGasket, Permatex, etc.
Thanks.
Old May 17, 2004 | 02:21 PM
Thunderbox's Avatar
Thunderbox
I would use brazing as the preffered material. It is the fitting on the side of the top of the filter housing that faces the engine. When you pull it off you will know you have the right one for sure. I am not sure where I read the TSB but I think it was on this sight.
Old May 17, 2004 | 02:30 PM
dpekin's Avatar
dpekin
I think there are 3 fittings on the top of the fuel filter. The one on the inside is not connected to anything. That must be it. I'll take a look at it when I get home.
Thanks
Old May 17, 2004 | 10:52 PM
dpekin's Avatar
dpekin
OK, I've looked at the filter and am not sure which fitting is the vent that allows the fuel to drain out of the line.
I'd appreciate any drawings or pictures describing how to fix the problem.
Thanks in advance.
Old May 18, 2004 | 12:23 AM
Spectramac's Avatar
Spectramac
It's the small rubber line that comes off the top side of the filter base. It should be a 1/4 inch hose. Just for testing, pinch the hose with some small vise grips and give it a try. The others should be metal pipes. The real problem is most likely an air leak in your return lines and injector o-rings.
Old May 18, 2004 | 11:12 AM
dpekin's Avatar
dpekin
Thanks. I'll give it a try. Wouldn't the leaks you suggest - o-rings, injectors cause a fuel leak? Why wouldn't those cause a problem when the truck is parked uphill and not downhill?
Thanks
Old May 18, 2004 | 01:15 PM
rbdutton's Avatar
rbdutton
Sometimes there can be an air leak that will allow air to suck in, but not allow fuel to run out. Also, as far as the problem with uphill/downhill, if you park facing downhill, the forces of gravity will keep fuel in the filters, etc. Park uphill and gravity pulls fuel away from them.
Old May 19, 2004 | 04:44 PM
mike in salem's Avatar
mike in salem
I am having the same problem. So I clamped off the return line that runs to the outlet side of the fuel filter. So far so good, it has not starved today after many restarts.
To find this line look at your fuel filter, on my '84 6.9 it is mounted on a bracket at the front of the motor over the right side valve cover, on the front of the bracket is the steel line comming from the transfer pump. On the rear is the outlet side that runs to the injection pump. On the fitting on the rear of the bracket, is a rubber fuel line that runs to the fuel return system for the injectors. I clamped this line. It makes sense to clamp this line. If you have an air leak, when you start your engine the air is pushed into the fuel line that goes to the injection pump, causing the fuel starvation problem.
With this line clamped the air is pumped back to the fuel tank because the return system from the injectors joins up with the return from the injection pump at the back of the motor. This will not cure your air leak, only releve the fuel starvation problem.
I hope this helps. Me as well as others.
Happy Trails
Mike
Old May 27, 2004 | 11:41 PM
dpekin's Avatar
dpekin
So, clamping the line fixes a problem w/ a leak somewhere else? Isn't that line a return so that the pump from the tank has a release so that it isn't pushing against a wall? If you clamp that line will the tank pump burn up or are there other adverse effects?
Thanks for any advice
-Dave
Old May 28, 2004 | 12:01 AM
kitsapcountychopper's Avatar
kitsapcountychopper
you do not have a in tank fuel pump on your vehicle you have a lift pump on it ,located on the pass side front of the eng.pinching the fuel line return hose will not hurt it
Old May 28, 2004 | 09:29 AM
mike in salem
These old trucks, mine is an 84, dont have electric in the tank fuel pumps. Just a mechanical "transfer pump" and then the high pressure "injector pump". Clamping this line just keeps the return system from dumping air into the supply to the injection pump.
Mike
Old May 28, 2004 | 11:32 AM
GunNut's Avatar
GunNut
This is odd. I was about to post the same problem here today. I am a total newbie to diesels and my 94 7.3L factory turbo 350 took a while to get started the past two days only after is sat overnight in my driveway pointed uphill. I will keep an eye on this thread and report any results from clamping or restricting holes.
This is an excellent forum, way over my head so far, but I like a good challenge!
Old Jun 1, 2004 | 10:22 AM
dpekin's Avatar
dpekin
I clamped off the return vent line from the filter back to the tank and the starting is better. Now I'll park on a steeper hill to really test the theory.
Thanks for the help.
-Dave
