High compression ethanol engine?
Old May 25, 2004 | 08:01 PM
fordeverpower's Avatar
fordeverpower
waterloo or ceder falls i believe!
Old May 25, 2004 | 10:51 PM
rusty70f100's Avatar
rusty70f100
Yep, near CF. Dont want to get too specific on the internet, you never know who is reading this.
I've done a search on the internet for E85 info and stations. The nearest station, as I can tell, is like 50 miles away. Too far for me. So I start building.
How high of compression do you think I could run with ethanol?
Old May 26, 2004 | 11:35 AM
Goffjb's Avatar
Goffjb
What about just using the ethanol as an additive? There has been a thread up in the general section of using acetone as an additive, and the guy that has been doing the study is getting 10% more mpg from just 8oz. of acetone per full tank.Also I tried just plain old 99% isopropyl alcohol in my truck last fill up and the truck in running really smooth now.
Old May 26, 2004 | 12:52 PM
muscletruck7379's Avatar
muscletruck7379
isn't isopropyl alcohol the same as rubbing alcohol?
Old May 26, 2004 | 02:35 PM
rusty70f100
Naa, the whole point is not having to pay $2.50 / gallon for fuel. You know that's where it's headed.
Old May 26, 2004 | 03:42 PM
Goffjb's Avatar
Goffjb
You all got it good, price of gas out here Seattle way is skyrocketing. $2.35 is average right now. and goes up every couple days
yepp rubbing alcohol. you can get small bottles for less then a buck. But I hear the denatured alcohol is better.
Old May 26, 2004 | 03:43 PM
muscletruck7379
as soon as that happens i will not be paying that for very long i can actually get someting done if motovated enough.
the last that i paid was 1.98 at sinclair for the "cheap" stuff, but considering that propane is 1.50 and all i need is the tank...
Old May 26, 2004 | 03:47 PM
muscletruck7379
how big is your tank of gas that your adding the 8oz too?
Old May 26, 2004 | 06:02 PM
Goffjb's Avatar
Goffjb
https://www.ford-trucks.com/forums/s...d.php?t=236403
here is the thread on the acetone booster.
Old May 26, 2004 | 08:26 PM
dinosaurfan's Avatar
dinosaurfan
ethanol, compression
Rusty, I think the ethanol 85 would have no problem with 12 to 1. But that is just my opinion, I have yet to try it. But the methanol guys run 14 to 1 with out trouble. If you are only 50 miles away, how about getting a 55 gallon drum and make a once a week or every other week trip and try it out. If it works well for your setup, then have at building the still and you won't have to drive to Cedar Falls anymore. DF, @ his Dad's
Old May 26, 2004 | 08:39 PM
rusty70f100
I may do just that. I'd probably get three 5 gallon gas cans and drive up there though. I dont need 55 gallons of the stuff just to see if its going to work!
In reality, I'm still messing with my new fuel injection system. I just got the exhaust fixed up and spiffy, and the tuning is progressing. It seems to idle nice and smooth now. Just a little tuning left.
What will probably end up happening is I'll see if I can get away with running the ethanol in my current 360. With the tunability of the fuel injection, I should have no problem tuning for it. Then, down the road, if the ethanol works good with the fuel injection (read: doesn't eat anything like fuel lines) then I'll build the high compression FE. This is definately a long term plan.
Does anyone know of a head gasket thinner than .020"? Also, with such high compression, should I use any different type of head gasket? I've heard of o-ringing it, what does that mean?
Old May 26, 2004 | 08:58 PM
dinosaurfan
head gaskets
Az, there are some steel shim gaskets from Ford , part number starts with a B. its .017 thick. DF
Greywolf
Alternative Fuels, Hybrids & Mileage
56
Oct 24, 2021 11:51 PM
2011FX2Crazy
2009 - 2014 F150
112
Aug 8, 2015 01:50 AM
RedTaurus94
20
Jun 10, 2014 04:39 PM
skyfox10
36
May 3, 2011 11:05 PM
LARIAT 85
35
Mar 12, 2011 09:09 PM
