General Automotive Discussion
Engine Identification
Old May 15, 2004 | 10:09 PM
Toyvo's Avatar
Toyvo
Is it a 360,390,400,or 460
I doctor freind asked me to repair the power steering on his 75 250 4x4 crew cab, so I said ok. Bad mistake! Well I dont have anything else to work on except a Fiat spider so this will be a snap in comparison. lol !!! The steering hasn't worked in like 20 years. It has or did have Power assist steering but the rack and pump with brackets are missing. It turns out that the engine was replaced with another rebuilt engine and along with that M/T valve covers, Edl. manifold and an AFB carb installed. We dont know it the same size engine was installed.
This sucker is large, larger than my 360 Dodge. Where are the numbers that will tell me what size it realy is so I can buy the brackets,and pulley to install my new pump? The spider is looking better all the time!
Old May 15, 2004 | 10:17 PM
Mil1ion's Avatar
Mil1ion
How many valve cover bolts does it have on each valve cover?
Also do the sparkplugs look like this / / / /
or like this / / \ \
Old May 16, 2004 | 07:56 AM
Toyvo's Avatar
Toyvo
I will go look this morning at the plugs and count the cover bolts. But I am thinking
// || dont know why. I will post here later today.
Old May 16, 2004 | 01:22 PM
Toyvo's Avatar
Toyvo
I looked at the plugs and they slant to the center. (// \\) The valve covers have 5 bolts each.
Old May 16, 2004 | 01:48 PM
Mil1ion's Avatar
Mil1ion
Ok, so now we know it is either a 360/390/428 .
I doubt it is a 428 so that means:
I have a feeling you are going to be measuring the stroke to see if it is the 360 or the 390.
Old May 16, 2004 | 02:00 PM
76supercab2's Avatar
76supercab2
Odds are if the engine is original it is a 360. But that's not important for what you're working on. Most/all FE's are identical on the outside so you just need a set of pump brackets for the FE family of engines. Look for something for a 360, 390, or 428. (352, 406, 410, 427 are also included but much rarer in trucks).
Old May 16, 2004 | 05:04 PM
Toyvo's Avatar
Toyvo
Thanks guys and or gals as the case may be.You are correct about checking the stroke. If it becomes ness. in the future I will do so. The issue here is infact the pump brackets. And now I can go get parts.
This is the best info site i have seen in quite some time.
Old May 16, 2004 | 08:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Off topic thread split.
ES5280
1978 - 1996 Big Bronco
Mar 23, 2010 12:41 AM
Hillcapper
Mar 28, 2009 08:46 PM
CommrclDiver
19
Oct 19, 2007 07:05 PM
mikeescott
Dec 17, 2004 10:38 AM
curt59
Aug 17, 2002 01:15 AM
