Need some help, roller lifter 'spider' install
Old Mar 26, 2009 | 08:57 PM
Hillcapper's Avatar
Hillcapper
Doing a 5.0 rebuild (roller motor), I installed lifters and dog bones then went to install the 'spider' hold down bracket. When I tighten down the two spider hold down bolts, the engine will not turn over by hand. Back them off a little and it rolls over (heads are on). These holes look 'blind' to me. I put bolts in by themselves without the spider, same thing happens.
The bolts do bottom out before the spider is seated all the way down. Does anything go under the spider? This thing was so nasty when I pulled it down but I don't recall anything under the spider. I've got a 302 manual but of course it doesnt reference roller rockers......
How could a bolt bottoming in what appears to be a blind hole keep the engine from turning over? Does anything go under the spider or do I have the wrong bolts in it (too long)?
Help!
Old Mar 26, 2009 | 10:53 PM
Beanscoot's Avatar
Beanscoot
Bolt length
I bet you really know the answer to the question "Does anything go under the spider or do I have the wrong bolts in it (too long)?"
Well, the camshaft.
Use shorter bolts. A good bolt length would be one that allows complete rotation when the bolt heads are bottomed out on the casting without the spider in place, then the added thickness of the spider would insure there's always adequate clearance.
Old Mar 26, 2009 | 11:57 PM
Conanski's Avatar
Conanski
Yeah... your bolts are too long. The really bad news is you may have damaged the cam bearings that are directly below these bolts holes.
Old Mar 27, 2009 | 06:52 AM
Hillcapper's Avatar
Hillcapper
Crap, the cam bearings are what I'm seeing at the bottom of the 'blind hole'. What an idiot I am, I looked in the holes to make sure that they were 'blind' since I knew the cam was right there but I was looking at the top of the cam bearing. Makes perfect sense.... Any suggestions on checking the cam bearing without pulling the cam back out? Maybe, pull cam gear and chain and insure cam rotates freely by hand? Should I be ok then?
Old Mar 27, 2009 | 08:24 AM
Hillcapper's Avatar
Hillcapper
I called the guy that did my block work, including installing cam bearings. He believes I will be ok, rotating assy rolls around as easily as it did before. Man, I am an idiot! Just something else to think about......
Old Mar 27, 2009 | 10:47 AM
lew52's Avatar
lew52
Sounds like it will be OK..Im sure all of us on here could tell some good storys of some of the stupid stuff we have done...Good luck..Lew
Old Mar 28, 2009 | 08:46 PM
Hillcapper's Avatar
Hillcapper
Thanks Lew, I think I've told you before but love your truck!
ranagent
29
Nov 19, 2017 05:53 PM
Zareen Shahin
2004 - 2008 F150
Jul 16, 2016 09:58 PM
cabloom300
Mar 22, 2016 08:12 AM
Coalhaulindady
Feb 10, 2016 11:57 PM
expeditionary
Aug 23, 2004 11:44 PM
