High Oil Pressure
Old May 16, 2004 | 12:12 AM
repairguy's Avatar
repairguy
High Oil Pressure
I have just gotten a 1977 F150 with a 351 modified 2BL. The engine is running rough. The oil pressure is high. I don't see any oil leaks outside of the engine. Any ideas what is going on?
Old May 16, 2004 | 12:23 AM
Mil1ion's Avatar
Mil1ion
This is an engine question not a 73-79 Truck specific question.
Thread will be moved to the 335 engine series forum.
It is less work for the mods if questions were posted in the proper forum.
Old May 16, 2004 | 12:19 PM
Ecuri's Avatar
Ecuri
The two things may not be related but, a place to start might be starting it with the valve covers off and see if oil is being pumped up each of the push rods. What are you considering high oil pressure? The stock guage basically amounts to a sophisticated idiot light for all practical purposes. Have you tried the basic cap/rotor/wires/plugs? Need more info!
Old May 16, 2004 | 03:37 PM
scroob's Avatar
scroob
Get a mechanical oil pressure gauge. The in dash units are notorious for bad readings. Also, many times people replace the sending units with units for idiot lights, which will give all kinds of weird readings.
As Ecuri said, it's likely the 2 problems are unrelated. I'd start with a tuneup.
Old May 16, 2004 | 11:52 PM
dimora's Avatar
dimora
What do you consider high? On initial start (Valvoline 5W-30) I see 90 PSI...once engine is warm, I cruise for hours at 58-62 PSI, and then at idle in DRIVE (stoplight, for example) I see 20...in PARK I see 30. I am running a Melling High Volume Oil pump in my 400. BTW, those pressures are with a SunPro mechanical Oil Pressure Gauge taken off the port between the fuel pump and the oil filter.
DiMora
Old May 17, 2004 | 07:42 AM
repairguy's Avatar
repairguy
True, I was just using the stock gauge, I will get a real gauge and hook it up. But basically the idiot gauge is running to high end as soon as the truck starts and while it is in it's rough idle. I have replaced, the spark plugs and wires, the cap and rotor seem good, but can replace. I will also mention, that I have rebuilt the carburetor, replaced the fuel pump and checked the vacuum lines for leaks. The idiot gauge was fine when we first bought the truck and this problem started once we drove the trucj back home.
Old May 17, 2004 | 09:03 AM
Shorbino's Avatar
Shorbino
I'm going to sound like a moron... Idiot gauge? I've heard books refer to it and it obviously it is an oil pressure guage... everyone else knows... what the heck is it?
Old May 17, 2004 | 11:52 PM
dimora's Avatar
dimora
Usually it is idiot light - meaning the light gives no useful information other that "you have a problem"...at least a gauge shows some real info if it is working correctly. I've never heard the term idiot gauge.
Old May 18, 2004 | 12:25 PM
Shorbino's Avatar
Shorbino
Idiot light is what I meant... think i got it figured out... purchased a oil pressure gauge. Is it as easy to hook up as the instructions make it sound?
- take out the oil pressure sending unit and hook up a nylon line from the block (where the oil pressure sending unit should go) to the back of the gauge?
I don't think I should be as nervous as I am, but i'm trying to hook this think up prior to starting a rebuilt engine (first one). thanks for the help.
Old May 18, 2004 | 10:22 PM
dimora's Avatar
dimora
You can do that, Shorbino, or go to Ace hardware and get some brass fittings so you can use your idiot light sensor and your gauge at the same time off that rear oil pressure port, or even better yet...with your oil filter off, you can install a fitting in the hole between the fuel pump port and the oil filter - that is what I did, and it worked great. You might even be able to install there without removing the oil filter, but I think it would be difficult. I bought an adapter fitting from Advance Auto to adapt the 3/8" NPT engine block hole to work with my AutoGage mechanical Oil pressure gauge fittings. Just use some Teflon plumbers tape on all the fittings so you don't get a leak. This is a pressurized oil port. See Bubba's site for a picture here:
http://home.earthlink.net/~bubbaf250/parts/pics02.html
It is the picture entitled "Crossover Oil Gallery Port ". Thanks, Bubba!
Regards,
DiMora
