Six speed auto
Old May 15, 2004 | 11:18 AM
F250Wheels's Avatar
F250Wheels
Six speed auto
I read in one of the post that the outo trans was six speed. Well got my ford shop manuals today and sure enough the auto trans is a six speed tranny, it skips forth gear under light loads, thats why it's called A five speed.
Old May 15, 2004 | 06:22 PM
SBV45's Avatar
SBV45
Where did you get the shop manuals? How much?
Old May 15, 2004 | 07:08 PM
mattsf250's Avatar
mattsf250
now, call me looney, but i am CERTAIN i have felt five shifts many, many times...you all can check as well, just leave from a stop a little harder than normal, and cruise to about 60 mph or so.....that would seem to show six forward speeds being used, and in another post we hear they only use five on upshift, and five on downshift, but downshifting it uses fourth gear which is not used on up shifting.....im cornfused.;...
go try it out, lemme know if you see the same thing!
but, keep in mind, fourth and fifth gear ratios are VERY close, and only causes a ~200-300 rpm difference, and the shift is only noticed by listening, and watching the tach.
Old May 15, 2004 | 07:13 PM
SBV45's Avatar
SBV45
Yep it shifts 5 times. A tech told me the last one is the torque converter lockup.
Old May 16, 2004 | 10:26 AM
Linemo's Avatar
Linemo
On the Ford shop manuals Q it is Helm Publications 1-800-782-4356 this is the Factory supplier!!!!!
Old May 16, 2004 | 01:18 PM
hitecdan's Avatar
hitecdan
According to the dieselmann:
"The 5R110W, or TorqShift, automatic transmission is a redesign of the E40D/4R100. Basically, the gear ratio for first gear was lowered from 2.71 : 1 to 3.09 : 1. To get second gear the overdrive clutch is engaged to give a ratio of 2.2 : 1. Third gear is now the same ratio as the old second gear, 1.54 : 1. The TorqShift is advertised as being a 5 speed automatic, when actually it has six forward speeds. On cold engine operation (below 0 degrees) the overdrive clutch is engaged in third gear for a ratio of 1.09 : 1. The transmission will shift directly to sixth from fourth and fifth is skipped. On a warm engine the shift pattern would be 1st, 2nd, 3rd, 5th (direct drive), 6th."
Link to the whole editorial, An Editorial by dieselmann
Volume 15; February 03: 6.0 PowerStroke and Torqshift Transmission
Old May 16, 2004 | 01:25 PM
johnsdiesel's Avatar
johnsdiesel
That's what I've heard as well. It has 6 speeds but will only use 5 at any one given time.
Old May 16, 2004 | 07:10 PM
powerstrokedieselboy's Avatar
Not to change the subject, but i heard that the torque shift tranny was made by allison. This came from a diesel mechanic of 30 years. Anyone else know of this.
I also was told if they did put an allison / torque shift in these trucks, that allison tranny's were always over kill. I know for an auto tranny on a big truck made by allison it used to be an extra 20 to 40 G, and when the truck was completely wore out the tranny could be pulled and used in another new truck wih no probs.
Just wondering??????
PSDboy
Old May 16, 2004 | 07:30 PM
F250Wheels's Avatar
F250Wheels
No it's not an allison, built by ford at a ford plant. I think this tranny is so bullet proof everone wants to label it an allison. Just be glad it is't, GM is having trouble with there allisons.
Old May 16, 2004 | 08:07 PM
psdwanabe's Avatar
psdwanabe
Though the Allison in GMs are a good tranny, they are not the godsend people think they are. They are no better than the Torqshift (so far).
Old May 16, 2004 | 08:11 PM
johnsdiesel
When the Duramax first came out people with modded trucks were having problems with the Allison going into "safe mode" because of the extra power. They are good transmissions, but they are no the "end all be all" in light duty truck transmissions. I've driven 2 2004 Duramax/Allison combos and the Allison has nothing on the Torqshift.
Old May 16, 2004 | 09:06 PM
F250Wheels's Avatar
F250Wheels
There having trouble because GM put some of there own parts in it.
