CAT antifreeze
Old May 14, 2004 | 12:45 PM
RickyBR's Avatar
RickyBR
Question CAT antifreeze
Has anyone replaced their green antifreeze with that red CAT antifreeze? I want to replace mine in my truck I just got. I'm gonna put ALL new fresh fluids in. I was told that the CAT stuff fights rust and corrosion. Anyone use it or know someone else that has?
Old May 14, 2004 | 12:56 PM
Fire Rooster's Avatar
Fire Rooster
This is only my opinion so use it at you r own disgretion. I would contact the dealer and find out if you can put the gold antifreeze in you PSD that came in the 2002 and newer trucks, find out what you need to do to flush the system completely and use it. Just my opinion.
Fire Rooster
Old May 14, 2004 | 01:07 PM
psdtenn's Avatar
psdtenn
All antifreeze/coolant products fight corrosion and rust among other things. Ford recommends against the use of ELC/OAT antifreeze in PSD's made before 2002. The CAT ELC antifreeze should work just make sure that you do a complete flush before using it. Remember, with most of the ELC coolants you won't have to add SCA. All my vehicles use low-silicate/low-phosphate Fleetcharge/Pencool 3000, its not recommended by Ford but in 60,000 miles I've had no problems. The conventional green coolant and ELC red coolant can cause problems when mixed, my little brother found this out the hard way when he tried to top off his radiator in his old Cougar with Dexcool after an initial fill with the regular green stuff.
Old May 14, 2004 | 04:10 PM
johnsdiesel's Avatar
johnsdiesel
The green and red stuff absolutely can not be mixed or it can gunk up your cooling system. From what I have heard you can use the gold coolant in place of green if you do a complete flush of the system. If you have 10% or more of the green stuff mixed with the gold then you have to add SCA, and in that case it would seem pointless unless you do the flush.
Old May 14, 2004 | 09:35 PM
psdtenn's Avatar
psdtenn
Something else I forgot to mention. The ELC/OAT coolant will also sludge if there is air intrusion into the cooling system. I've seen several Dexcool-equipped Chevrolet's where the intake manifold had to be replaced because of this. Make sure a complete system flush is done and that the cooling system is free of trapped air.
Old May 14, 2004 | 11:02 PM
heavywrench's Avatar
heavywrench
i work for a cat dealer as a field service mechanic and as long as you make sure you flush all the green out you wont have a problem.
Old May 15, 2004 | 07:22 AM
RickyBR's Avatar
RickyBR
how do I flush the system to make sure that it is all out?
gbrewer
Dec 27, 2010 11:22 PM
broncobuster7
Dec 6, 2006 12:05 PM
Calli
May 25, 2006 06:39 AM
b4hntn
1978 - 1996 Big Bronco
Apr 7, 2005 05:41 AM
rmilchman
13
Feb 22, 2003 07:02 PM
