Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Fly Control?
Old May 14, 2004 | 06:55 AM
Bruker's Avatar
Bruker
Fly Control?
I live in a rural area and farming is one of the main industries in this area. I've grown up in this area and I wouldn't trade it for anything but when the neihboring farmer hauls manure the fly population gets 10x worse. Has anyone ever tried the "plastic bag of water over the door" or any other methods to repel the pesky flies.
Old May 14, 2004 | 01:46 PM
camo4stealth's Avatar
camo4stealth
Bruker, I can tell you of the most efficient fly trap yet devised. Take a 2 gallon jar (the kind that institutional kitchens have mayo or stuff in). Make a small hole (1/4 inch) in the top. Place something smelly, like raw meat or a small dead fish in the bottom. You may want to place it on top of an inverted cup or something. Fill the jar with about 2 inches of water. You will not believe how many flies go in after the smell, but the clear glass is like a window to them, and they don't come back out. Emptying the trap is up to you.
Old May 14, 2004 | 02:19 PM
KenB's Avatar
KenB
The clear bag of plain water helps in some conditions, you'll have to try to see if it'll help in yours.
Hang in well lit areas, and it's going to take numerous bags, not just one or two.
The bags play havoc with the flys ability to see correctly with the light being refracted through the water. I guess it gives them a fly headache.
The other idea will work, BUT, you end up having to put up with the stench from the bait/trap. It can also be a draw to an even wider area of flies as the odor gets carried in the air. Bit it does work.
Do an internet search for "fly-control", there are some other interesting possibilities out there.
Old May 14, 2004 | 04:46 PM
triton_2002's Avatar
triton_2002
I always wondered how the bag of water trick worked, I guess I learned something new today.
Old May 14, 2004 | 04:51 PM
nick88f150's Avatar
nick88f150
we always had pretty good success with those sticky strip things that hang from the ceiling
Old May 15, 2004 | 12:30 AM
Torque1st's Avatar
Torque1st
Posting Legend
Any bait type trap will draw flies, make sure you use them a long way away from the garage.
Make sure the household trash and garbage or any recycling marterials are not stored anywhere near the garage. Flies can smell garbage thru a tight fitting metal container. Those odor molecules leak out. No trash can is gas tight.
I use a few shots of aerosol fly killer after I finish working. Those pest strips seem to work well.
A bigger problem in the summer here is mosquitos. I have found the "bubba fan" described in some old posts here to be a good solution for that problem. It helps with the flies also.
IHateCommieCars
May 6, 2016 01:09 PM
dmanlyr
Large Truck
Sep 9, 2014 10:29 PM
Gary K G
Mar 20, 2014 09:27 PM
SuperDuty93
27
Jun 30, 2011 08:13 AM
flying scotsman
Offroad & 4x4
Aug 15, 2004 02:56 PM
