Offroad & 4x4
What will fit ?????
Old Aug 12, 2004 | 10:02 PM
flying scotsman's Avatar
flying scotsman
Question What will fit ?????
how big of a tire can I fit on my stock Bronco II??
Old Aug 12, 2004 | 11:11 PM
Muddr Trukkr's Avatar
Muddr Trukkr
31" tires without rubbing
Old Aug 13, 2004 | 10:04 PM
JeremyH's Avatar
JeremyH
44" without rubbing
Old Aug 14, 2004 | 03:11 AM
Muddr Trukkr
ohhhh, stock, yeah i didnt see, with a 3 inch body lift you could put 49's in there.
Old Aug 15, 2004 | 11:03 AM
fishmanndotcom's Avatar
fishmanndotcom
OMG! another tire size question?
try their suggestions first and then try mine!
ok for every Dana that your front axle is that is the size tire you can run! Example: I used to have a Dana 50 up front so i could fit a 50" tire. I swapped in a Dana 60 so i can now run a 60" tire!
If i remeber correctly I beleive the BII's have the Dana 35's so you can run a a max of 35" tire! but if you have the Dana 44 solid axle you can run either a 44" tire or a 46" tire b/c of the solid axle capability!
good luck
-cutts-
Old Aug 15, 2004 | 02:22 PM
JeremyH's Avatar
JeremyH
Hell......a dana 35 should only run a 33" tire max when it is open....locked....a 31 will break that axle.
Old Aug 15, 2004 | 02:56 PM
fishmanndotcom
actually i busted one on my buddies EB with the D35 with 25" trailer tires on it, lol! it actually cracked the carrier and snapped a pass inner (the long one). i was playing on a hill and my front end came up and when i caught traction again my front tires were spinning about 70 mph! it wasn't pretty!
-cutts-
petrokiller
Jan 22, 2017 07:04 PM
eberf
Oct 11, 2016 09:06 AM
jgilrfr
Sep 20, 2016 06:17 AM
GocartMozart
Jan 10, 2016 08:17 AM
Paarrothead
Exhaust Systems
May 23, 2002 07:26 PM
