Aerostar Ford Aerostar
starter problem??
Old May 12, 2004 | 08:44 PM
roree's Avatar
roree
starter problem??
Just had the '92 aerostar towed home. It clicks, but the starter just won't turn. Headlights are strong and when we tried to jump it from the tow truck, it still wouldn't turn over. I am sure the battery is ok. Sound like the starter to you guys? If so, how hard of a job is replacing the starter? Thanks.
Old May 12, 2004 | 08:53 PM
jkorreck's Avatar
jkorreck
Sounds like a starter to me, if your engine is a 3.0L 2wd it's really easy, did mine in about 15 mins. (I was motivated by very cold weather, no heated garage, and a need to make it run again)
Old May 12, 2004 | 08:56 PM
M.Herrington's Avatar
M.Herrington
did it under 10 on 3.0, three bolts, two wires, just make sure you disconnect one of the battery cables from the battery first.
Old May 12, 2004 | 09:03 PM
roree's Avatar
roree
Thanks guys. I'll replace it tomorrow afternoon. Don't worry, I won't be breaking anyone's speed record.
Old May 13, 2004 | 07:04 PM
Beast12's Avatar
Beast12
It could be your battery cable as well. You can try to smack the starter with a hammer and that could get it going for a bit. Good luck!
-Matt
Old May 15, 2004 | 09:22 PM
roree's Avatar
roree
The starter was pretty simple. You will need 13mm socket(pref. deep). Open end wrenches will take longer. Be prepared to strip the small solenoid wire and splice it into the new supplied butt connector. Make sure you disconnect the battery. Ramps are ideal for this job. Hope this helps anybody else that is attempting the job.
Old Jul 25, 2004 | 08:15 PM
Fremen's Avatar
Fremen
Its a dead spot in the starter. Mine does it as well once in a while. Just give it a couple of hits with a hammer
Old Jul 25, 2004 | 10:18 PM
jasonbbq's Avatar
jasonbbq
If you need to hit it with a hammer, it might be time to lot into puchasing a new set of brushes for the starter. If you let it go too long the starter will leave you stranded.-jc
Old Jul 26, 2004 | 05:53 AM
Beast12's Avatar
Beast12
I agree. Starters are so cheap nowadays it is not worth trying to save them!
-Matt
Old Jul 26, 2004 | 11:20 AM
copper_90680's Avatar
copper_90680
If you have a 4.0L with E-4WD, it's a bit harder since you would have no clearance to pull it out. You end up having to disconnect the front drive shaft from the front differential to move the driveshaft out of the way. Even then, it ain't pretty. For the 3.0L, yes it can be done fairly easily. Did mine in the McDonald's parking lot
Csilcox
2009 - 2014 F150
Feb 25, 2017 10:05 AM
81ChopTop
Apr 23, 2016 06:41 PM
Subaru Sti
Sep 19, 2014 11:03 AM
SteelerSal
Nov 11, 2013 06:19 AM
arkredneck
Jan 8, 2010 12:45 PM
