How do I check my engine temp?
Old May 12, 2004 | 02:29 PM
Tamalpais's Avatar
Tamalpais
Question How do I check my engine temp?
A couple of weeks ago someone mentioned using a meat/candy thermometer to get an actual temp reading.
Is that trick for checking water temp, as in taking the radiator cap off and dipping in the coolant, or is their a better way? Thanks.
Old May 12, 2004 | 02:53 PM
fish_bulb's Avatar
fish_bulb
that sounds hot and dangerous. I'd stick with the old fashion "sending unit in the intake manifold" trick
Old May 12, 2004 | 03:39 PM
green 79's Avatar
green 79
8th Gear
I used the meat termometer method just the other day to check and see if my thermostat was opening properly. Do this in the morning when the engine is completely cool. Before you start the motor, take off the radiator cap and put the meat thermometer in, then start the motor and wait. When the engine temp reaches 180 or whatever your t-stat is rated for, the thermostat will open and the temp in the radiator will rise to that temp. You should also notice the water moving in the radiator when the t-stat opens, if the water doesn't flow and the temp climbs to over 200 you may need to change your thermostat. This method helped me diagnose a malfuntioning thermostat.
Old May 12, 2004 | 06:19 PM
Mil1ion's Avatar
Mil1ion
Thanks green, That's what I tell people myself.
It is the safer way of doing it.
Welcome to FTE!
Chance_Thomas
All Things Towing
28
Aug 15, 2013 08:02 PM
Atc210
Jul 14, 2012 06:02 PM
Dragrazor
Electrical Systems/Wiring
28
Nov 17, 2007 10:02 PM
vortec
Nov 1, 2007 10:47 AM
