ignition (switch?) problem????
Old May 12, 2004 | 03:39 AM
ahawes's Avatar
ahawes
Angry ignition (switch?) problem????
ok well here it is. tonight i drove about 8 miles to my friends house, about an eighth mile down his bumpy *** driveway, a couple hrs later go back down the bumpy *** driveway (truck started fine) to my girlfriends house. im there for a few hrs, go to leave and my truck wont run unless the switch is in the start position. so i undo the cable from the starter push start the truck, holding the switch into the start position and haul *** 8 miles back home.... now im thinking my solenoid is porbably going to be fried by the time i get home, or at least some wiring somehwere.... i get home, pop the hood, sloenoid is nice and cool and all wires everywhere on the truck are cool to the touch..... what could be causing this problem? the truck is a 59 f-100 if that matters
adam
Old May 12, 2004 | 03:56 AM
angus's Avatar
angus
Ballast resistor! That fits the symptons. It's the ceramic rectangle (usually) on the firewall or near the coil. Could be the resistor is open circuit, or just a bad connection or busted wire in the circuit.
The starter solenoid has an extra contact that bypasses the resistor to apply full battery voltage to the coil (to make up for the lower battery voltage during starting). That's the extra small wire running from the solenoid to the coil.
Old May 12, 2004 | 10:44 AM
Jag Red 54's Avatar
Jag Red 54
I'll vote that the solenoid is bad or the wire to the run side is loose. Is there juice to the run side with the key in the run position? Just threw that in in case it is not the ballast resister.
Old May 13, 2004 | 11:50 AM
Jag Red 54's Avatar
Jag Red 54
Well, did you ever find the problem? Future readers will want to know what your solution was. John
Old May 14, 2004 | 01:53 AM
ahawes's Avatar
ahawes
havent gotten around to workin on the rtuck yet. ive just been riding my streetbike every day. im going to replace the ballast resistor this weekend. i'll be sure to let you all know what was happening as soon as i fix it. thanks for the info guys
adam
Old May 14, 2004 | 07:36 AM
Midnite Cruiser's Avatar
Midnite Cruiser
Clean,Check, dielectric grease every ground conn too while you are digging.
Old May 18, 2004 | 02:55 AM
ahawes's Avatar
ahawes
it was the ballast resistor... finally got around to fixing it today. simple fix. replaced it with an MSD unit and its working perfectly once again. thanks for the help guys
adam
Old May 18, 2004 | 08:18 AM
packrat56's Avatar
packrat56
I want to go ahead and replace my ballast resistor, looks like its been there a very long time and I drive this vehicle every day. Are all 12 volt ballast resistors the same? Are they specific to the vehicle? Better brands? 56 with a 302.
Old May 18, 2004 | 05:02 PM
ahawes's Avatar
ahawes
i beleive they are pretty much all the same thing. theyre cheap too. i got my MSD unit in a package with a blaster 2 coil so im not sure how much the resistor itself runs
adam
Dirt Racer96m
Apr 15, 2014 11:44 PM
acf6
Apr 13, 2014 03:01 PM
texastud1983
Jan 19, 2009 12:19 PM
texastud1983
Jan 16, 2009 11:48 AM
abcdefg1675
Aug 21, 2008 12:21 PM
