Activator II on 2000 Excursion XLT. Help
Old May 11, 2004 | 09:08 PM
Y2KExcursion's Avatar
Y2KExcursion
Hi All,
I am looking to put a Drawtite Activator II on my 2000 excursion. I am using the factory grey connector with the red, white, blue, Lt. green and brown wires. The activator II has red, blue, white and black. I can match up the ones that match but what do I do with the black one from the brake control and the Lt. green and brown from the factory connector? They must go somewhere. I know someone out there has connected one of these, can you tell me the right direction.
Thanks.
Old May 12, 2004 | 12:42 PM
Toyman's Avatar
Toyman
The red is constant hot, the blue runs back to the trailer brakes, the black is switched power(from the ignition), the green picks up power from the brake light switch, the brown is a dash light circuit, and the whit is ground. It should be labled on the factory harness which wire is for what, and the contoller you purchased should have the wires marked also. Do not assume that the wires are color coated to match, they are not. Look carefully on the wire, and/or read the instructions completely before you hook the wires up and find that nothing works correctly. If you do not have instructions you may be able find them on the internet.
Toyman
Old May 12, 2004 | 12:44 PM
Toyman's Avatar
Toyman
Sorry I was wrong already. The black is the ground the red is the switched power. Everything else is as I stated.
Sorry, Toyman
Garry Chapman
Dec 29, 2013 08:58 AM
dosecobanya
1997 - 2003 F150
Aug 30, 2012 04:26 PM
Ed2
All Things Towing
Mar 17, 2004 12:20 PM
Fords For Ever
Apr 16, 2003 11:40 AM
