Sponsored by: Real Truck
FX package spring lift difference??
Old May 11, 2004 | 07:10 PM
ada_scout's Avatar
ada_scout
Question FX package spring lift difference??
I have a "regular" F-250 SuperDuty 4x4 with the 5.4 motor. I have heard that the FX package springs have a little more lift to them. Does anyone know how much more lift they give? Also, if anyone has part numbers for the front and rear FX springs, I would appreciate it. I have the 4.5" plush ride kit from Edge and would like just a tad more lift, if possible. Any help??
Old May 11, 2004 | 07:28 PM
DCSpecial's Avatar
DCSpecial
FX4 package doesn't affect springs to the best of my knowledge.......you get decals, "Rancho" shocks, and some skidplates.
If you want more lift up front the X-code springs (come with snow plow package and F-450 and F-550 PSDs) will make the front sit the highest.
Not sure about different rear springs giving more lift......
Hope this helps.
Old May 11, 2004 | 07:32 PM
johnsdiesel's Avatar
johnsdiesel
The springs are not changed with the FX4 package. This is what you get (taken from Ford's website):
Transfer Case and Fuel Tank Skid Plates
Branded Rancho Front and Rear Shocks
Steering Damper
"FX4" Decal
Old May 11, 2004 | 07:37 PM
ada_scout's Avatar
ada_scout
Talking
Ok, so if they don't have different springs, what makes them look like they sit a little higher than a "regular" SuperDuty? Do they maybe have these "X" code springs I have heard about? Does anyone know how much these springs cost and where to get them from? How much more lift do they give you over other Ford springs. Where do you look to see what code springs you have?
Old May 11, 2004 | 07:41 PM
johnsdiesel
The X springs raise the front of the truck and are designed for plow trucks. There are no options that raise the rear of the truck. Is it possible that the trucks you have seen have a lift installed? I know some dealers install lifts in new trucks before they are sold.
Old May 11, 2004 | 07:42 PM
DCSpecial's Avatar
DCSpecial
You can get the X-codes from a Ford Dealer.....not sure on cost. Depending on what code springs you have now you should get 1-1.5" or more out of the X-code springs.
To see what springs you have now look at the sticker on your driver's side door jamb and look under where it says "SPR", there should be two letters and the first letter is what code front springs you have. Or if you look towards the upper left of the sticker for "Front GAWR" the X-codes are 6000#, v-codes are 5200#, u-codes are 4800#, etc..
Hope this helps.
Old May 11, 2004 | 07:50 PM
ada_scout's Avatar
ada_scout
Talking
I looked on my sticker and I have the TA code springs. Would the "X" code springs give me enough of a lift to bother with? Like I said, I already have the 4.5 inch plush ride system but would like just a little more if possible. Think it is worth it?
P.S. - Thanks for all of you help guys!
Old May 11, 2004 | 08:12 PM
04superduty's Avatar
04superduty
The x springs would give you more lift but would make your rider stiffer expecially on a truck with a 5.4.
Old May 11, 2004 | 08:23 PM
ada_scout's Avatar
ada_scout
I figured it would make it a little stiffer, 04superduty. But, with a good set of shocks (I have Blisteins all around now) and possibly a dual front shock setup, it shouldn't be too bad, should it? Since I do have the "lighter" 5.4 engine, how much more lift do you think it will produce?
Old May 11, 2004 | 08:24 PM
jlstorm's Avatar
jlstorm
I dunno
I have had my 250 fx4 next to a 99 4x4 and a 2003 regular 250 and it was definitely higher than the regular 250 and looked like it had a 2 or 3 inches on the 4x4. Maybe it rode higher cause of the lighter engine (5.4L), I mean there was a noticable difference on flat pavement. I dont know what engine the other 250s had. I didnt notice a V10 emblem.
Old May 11, 2004 | 08:26 PM
johnsdiesel
Sounds like the old placebo effect!
Old May 11, 2004 | 08:27 PM
04superduty
My boss has a f 250, regular cab, long box, plow prep with the 5.4 and it rides like crap. Bounces back and forth. I am not sure about the amount of lift the x springs would actually give you.
Old May 11, 2004 | 08:43 PM
jlstorm's Avatar
jlstorm
I have not ruled that out yet...
Old May 11, 2004 | 09:33 PM
Yeti's Avatar
Yeti
Like it has been said hundreds of times on here, the FX4 icludes:
Transfer Case and Fuel Tank Skid Plates (light weight)
Branded Rancho Front and Rear Shocks (not to good ones at that)
Steering Damper
"FX4" decal
That is it, If a truck with the FX4 package has a 5.4 and X springs, it will sit higher in the front, than any other super duty with less spring or more motor.
All else is a figment of ones own imagination.....
Old May 11, 2004 | 10:57 PM
johnsdiesel
Steering Damper
"FX4" decal
But on the F250 the springs are different...
