turn signal problems
Old May 11, 2004 | 05:01 PM
3headedboris's Avatar
3headedboris
I have a 1964 F100
when I turn on the flasher for either direction both lights flash but only on the rear. this just started suddenly and I am wondering if anyone has had this problem and what to do about it
thanks
Old May 11, 2004 | 10:08 PM
MyDads64's Avatar
MyDads64
I had the same problem with my 64 F100. I tried several things, but wound up getting a new directional signal switch and it fixed it. The old directional signal switch mechanism was worn out. I tried to adjust it a couple of times, but finally replaced it. I had a bit of trouble finding the switch, but finally found it at Johns F-Fun Hundreds.
Norwood Shelton
Monroe, LA
64 F100, 55 Customline
Old May 12, 2004 | 09:24 AM
MercuryM100's Avatar
MercuryM100
My signals were doing a very similar thing....
I ended up changing the signal relay (in the dash behind the speedometer) for about $5.00 and it solved the problem immediately.
Good luck!
Chad
Old May 12, 2004 | 07:37 PM
Dads66's Avatar
Dads66
When i ran into this problem on my 66 i found that there is a switch on the dash that i'm not even sure what it is for (if someone knows please let me know) but is next to the choke **** was pulled out and apparently causes the signals to ground or something. Pushed the switch back in and everything is good.
durst2020
Nov 1, 2011 11:15 AM
Duke78
Jan 17, 2010 04:58 AM
hertz1438
Oct 16, 2009 06:42 PM
mdjwahl
1997 - 2003 F150
Jul 18, 2007 09:50 AM
daveroconn
New Member Introductions
Dec 18, 2006 05:25 PM
