Holly to a Ford
Old May 10, 2004 | 09:20 PM
Lionsfan's Avatar
Lionsfan
Question Holly to a Ford
I want to place a Ford 4350 on a 390 Ford. It originally came stock with a Holly.I need a spacer plate. Is there any difference between plates. There is two available to me. There is one flat plate with one large hole for around $ 23.00 or there is a plate that matches holes for around $150.00 Help can I use the cheaper model?
Old May 11, 2004 | 09:05 PM
79stepside's Avatar
79stepside
you could go with the one that is one big hole but i think it would be best to go with the 4 port just to keep things even flowing
Old May 11, 2004 | 09:49 PM
Lionsfan's Avatar
Lionsfan
Talking Thanks for the reply
Thank you I found one at Summit Racing products. Its on the way.I felt better with a tight fit.
Old May 11, 2004 | 11:04 PM
LxMan1's Avatar
LxMan1
The open hole spacer on a 4 hole intake will cause a lot of turbulence between the carb and intake. Those are designed for open plenum intakes. The 4 hole spacer is the way to go.
Old May 12, 2004 | 09:22 AM
fordboy_52's Avatar
fordboy_52
go to your local bumper to bumper store and get a dam edelbrock 650 and u will be set, best carbs on the market for street use
Matt
