making the holley 600 performance?
Old May 10, 2004 | 08:48 PM
79stepside's Avatar
79stepside
i am in the process of rebuilding my first carb which is the holley 600 on my 79 ford stepside i was wondering if holley 600's are able to make performance or should i upgrade to a 750 or a 950? any help most appreciative and thanks in advance.
Old May 10, 2004 | 10:58 PM
LxMan1's Avatar
LxMan1
Hi and welcome. what size engine are you running? The 600 is a good performance carb for a small block engine.
Old May 11, 2004 | 04:22 AM
62uni4x4's Avatar
62uni4x4
Unhappy Big Carburator
Well stepside,
One of the most comon mistakes people make is to over carburate.
If you are not running a 460 with a healthy cam and dove heads or a modified with c 4v heads or something like that stay with the 600.
It is plenty of carburator for a stock 351 or 400 especially in a truck application.
Thats just my opinion anyway for what its worth......
John G
Old May 11, 2004 | 08:31 PM
79stepside's Avatar
79stepside
right now i have a 351M with stock manifolds which i plan on replacing with some hooker headers, and as far as heads go im not sure which would be go and for cam i dont know much about it the guy told me it had a 500 lift if that helps any, and for last but not least it has 77,890 original miles on it and never been rebuilt
i also have another question would my 351M be worth making performance? because i am gonna be quite honest it sure it one clean lookin motor and starts on the dime without hesitation
Old May 11, 2004 | 10:48 PM
LxMan1's Avatar
LxMan1
The 600 on an Edelbrock Performer manifold will work fine. Add some headers and a 2-1/4" dual exhaust system with either s set of good turbo mufflers or a set of Flowmasters.
Old May 11, 2004 | 11:44 PM
79stepside's Avatar
79stepside
sounds like a good idea
Old May 12, 2004 | 03:39 AM
62uni4x4's Avatar
62uni4x4
Arrow
You should look into a set of aussie cleavland heads they are cuenched chambers with 2v ports They are excellent for truck motors.
Also the 351m is by no means a "performance motor" but they are dependable and produce gobs of torque when set up right.
They are really good truck engines and prepared properly will make plenty of power
John g
Old May 12, 2004 | 09:18 PM
79stepside's Avatar
79stepside
well i am not looking to make a drag racing performance but i do want it to be better then what it can be
whisler
30
Mar 20, 2011 10:03 AM
clean79150
May 7, 2005 09:59 PM
bartfc
Nov 14, 2002 08:37 PM
vwmeoww
Dec 1, 2000 07:44 AM
