1978 - 1996 Big Bronco
4X4 question
Old May 10, 2004 | 06:56 PM
BroncShane's Avatar
BroncShane
4X4 question
My 89 EB has an auto transfer case. Of course there is no owners manual so I have to ask a couple of silly questions.
How do I shift the truck into low range?
AND The big one...
Can the transfer case be put into Neautral like my 82?
Thanks
Old May 10, 2004 | 07:26 PM
dyarumian's Avatar
dyarumian
Im assuming its a manual shift so to get into neautral pull back thats 4 high then push down and back a little thats neautral than back again then your in 4 low
2h__4h
..........\_N__4L
Old May 10, 2004 | 07:47 PM
BOJOFASO's Avatar
BOJOFASO
with an electric transfer case you need to put the trans in nuetral then you press the 4x4 high button then you hit the low range button.if you have auto hubs they will engage as you start to drive forward as long as the front driveshaft is spinning.
Old May 11, 2004 | 10:44 AM
djjoshuad's Avatar
djjoshuad
actually, if you have an electric transfer case, you don't have to put the transmission in neutral. you can actually shift to 4hi at any speed up to 55mph, as long as your hubs are locked. This is straight out of my '93 manual. Also, on the electric, it's either 2hi, 4hi, or 4lo. no N.
kbf1961
Jan 25, 2012 03:13 PM
for46016
Feb 11, 2009 10:58 PM
blownbronco
Dec 29, 2002 12:14 AM
aunchman
Aug 6, 2002 06:06 PM
