Testing coil packs
Old May 10, 2004 | 11:51 AM
KLAFSU0494's Avatar
KLAFSU0494
Testing coil packs
Can anyone tell me how you test the cop's on a 5.4. I have a multimeter, but I'm not sure where to put the + & - leads to test it, and what kind of reading should I get? I've tried to find info on this and I have been unsuccessful.
Thanks,
Kevin
Old May 10, 2004 | 01:07 PM
n578md's Avatar
n578md
There's only two leads on my coil terminals (2003 F250 5.4L) and it doesn't matter what polarity is used since you're not testing a diode or a transistor. I've read in another post that "normal" coils should read between 0.5 Ohms and 1.5 Ohms. All 8 of my coil read the same 0.8 Ohms. 0 Ohmns means there is a break in the coil winding and above 1.5 Ohmns means the winding is shorted out or corroded, either way it's bad news.
Kevin Ostrom
New Member Introductions
Jan 14, 2014 10:34 PM
Rokcrln
30
Jan 10, 2014 12:21 PM
kevin j. mahoney
Nov 21, 2011 01:48 PM
Kevin In MN
16
Oct 23, 2010 02:15 PM
kevin.ford-trucks
Jul 4, 2008 07:42 AM
