Time for the good stuff
Old Mar 21, 2002 | 10:58 AM
Skeetshooter's Avatar
Skeetshooter
Gentlemen, It has been some time in coming but I now have the means to upgrade my 2k PSD with exhaust, A-pillar gauge array and performance chip. In reading posts on this and other forums I need some guidance on the down pipe (ID/OD) selection. Some users praise the 3" to 4” down pipe and others the 3" to 3.5” setup. What are the benefits of the 4" over the 3.5”? I have read that the 4” will drop your low-end torque, is this so? I have an automatic transmission and don’t want to loose the low-end benefits when pulling. I want to purchase the right products the first time. Any help and guidance will be greatly appreciated.
Thx, Jeff
Some call it a 6-pack, I call it a support group.
Old Mar 21, 2002 | 04:30 PM
powerstroker250's Avatar
powerstroker250
I have not upgraded my exhaust but these trucks come with 3" into 3 1/2". I've heard that the best results come from 3 1/2" into 4". My neighbor tried 4" all the way and lost the low end then went back to the 3 1/2" into 4" configuration.
Les
Old Mar 21, 2002 | 09:47 PM
wildjon300ci's Avatar
wildjon300ci
I don't believe it would hurt anything on the low end side of the power by going to a 4 incher........the turbo and the manifold supplies all the backpressure the engine needs.
Old Mar 23, 2002 | 12:38 PM
red99sdv10's Avatar
red99sdv10
IMO a 4" dp without a chip will loose power
been there done that.
with a 80 hp sc I still have the 3" dp to a 4" exhaust without a muffler.
my chip is custom programmed adn I do not have any trouble with egts as of yet when towing.
if I add more power then I may go to a 3.5 dp but not likely.
2000 PSD slightly modified
Old Mar 25, 2002 | 11:17 AM
Skeetshooter
Thanks for the advice and input.
Jeff...OUT
Old Mar 26, 2002 | 04:35 PM
jetech's Avatar
jetech
[updated:LAST EDITED ON 26-Mar-02 AT 05:38 PM (EST)] I have an '00 PSD with the K&N airfilter, no catilyst, stock downpipe to the Pro-Flow muffler which has 4" in and 4" out to a high volume "Y" pipe that is 4" to the left and right 5"x12" chrome slant cut tips. This Baby has a deep mellow tone and a load open loop turbo roar when she is warming up. I wanted a louder sound but I could not find a muffler that would stand up to the volme/pressures of a 7.3. Fanasy Muffler in Midwest City, Oklahoma off of N.E.23rd St. did my work. Don't let'um tell ya ya can't put duals on a diesel. By the way, my truck came factory without a catalytic converter and large fuel filler neck, no restricker at the filler cap. Cool hu?
Old Mar 26, 2002 | 05:06 PM
jetech's Avatar
jetech
